Author Topic: 3.2 MV6 - My DIY LPG Conversion  (Read 8590 times)
Re: 3.2 MV6 - My DIY LPG Conversion
« Reply #15 on: 20 December 2011, 09:43:17 »
Agree with Chris, but it all ended ok :y
Looks nice and tidy :y The only thing we have started doing differently (other than the butchery surgery on the interrupt wiring to use the big Vx injector plug) is take the vac reference from a tee on the servo line :y
This is what Gaffers did initially and the MAP was all over the place every time the brake pedal was pressed. Also, the MAP hit 100kPa at about half throttle. I did wonder if the brake servo was leaking (it held vacuum with the engine stopped for a good few pumps of the pedal, though). Be interested to know if there's any effect from the servo on other cars plumbed this way.
Still, looks a nice job, James. Second nature by now, though. :y
worth a look :y
although both mine have been done that way, no issues attributed to it, iirc...?
Mine done that way and so's TBE, both with no ill effects :y
I wouldn't expect there to be, TBH, which is why I was a bit baffled by Gaffers' issue. We drew a bit of a blank, so put a nozzle in the plenum and, AFAIK, it has been fine since. I think there must have been a leak into the servo but, as I say, you could stop the engine, and it held enough vacuum for a half dozen pumps of the pedal. :-\
« Reply #16 on: 20 December 2011, 09:45:20 »
worth a look :y
not the old "servo pipe rubbed through on the ac pipe" favorite then...?
« Reply #17 on: 20 December 2011, 09:47:39 »
No leaks that we could find, and, as I say, air drawn from the servo was certainly making a  big impact. On hindsight I do wonder if the pipe was partially blocked.
« Reply #18 on: 20 December 2011, 10:35:37 »
Happy to take any required pics of TBE, which obviously has been certified, first attempt.
How did you get on with certification JamesV6?
« Reply #19 on: 20 December 2011, 11:34:06 »
Yep, or my estate. When it was inspected we had a bit of a discussion about a couple of things but it passed and they commented that it was far neater than any of their conversions ::) ;D :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #20 on: 20 December 2011, 13:31:09 »
Have any of you lads got any pictures of the mounting and plumbing of the KME Gold reducer on the 3ltr V6 ?
I had a right ball ache getting mine to fit down there and tbh i've still got some tidying up to do on that side  :-[
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #21 on: 20 December 2011, 13:42:13 »
MAP is still off a bit although it is steady now when you press the pedal.  I wonder if that is causing the misfire issue I have....
Not had the time to look at it properly yet as I have other priorities right now but the blocked line is a real possibility as the breather box pipes on the trumpets were blocked when I first got the car.  Yet I remember taking the line off and feeling the neg pressure in the t-piece and then unplugging the line next to the MAP sensor there was still neg pressure.  I suppose a partial blockage could be possible but then the MAP would just be slower to react surely rather than reading 0.08-0.1 too high.
By the way, who the f£$% is Gaffers?  ::)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #22 on: 20 December 2011, 15:24:36 »
Mine comes off the servo with no ill effect
« Reply #23 on: 20 December 2011, 18:28:58 »
agree it is tight, and fiddly, with ltd access. Plues leaving room to get access to the allen key adjuster doesnt help.
Although dbw engine bay helps.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #24 on: 20 December 2011, 18:57:26 »
Tell me about it   :)
Pain in the arse  ;D
Has anybody totally removed the EGR side of the engine on a 2.5 / 3ltr engine and shorted out the plug on here ?  :-\
« Reply #25 on: 20 December 2011, 19:18:24 »
TheDaddy...
I would leave the egr as-is...
« Reply #26 on: 20 December 2011, 20:49:22 »
Is this taken from the Vac line between the servo and the Non return valve, or between the valve and the plenum :-\
