Author Topic: aerial/hrw  (Read 6489 times)
aerial/hrw
« on: 21 December 2011, 18:51:49 »
Just remind me .............  ;D ;D ;D
my radio reception has now down graded itself to a crackle if I turn the heated rear screen on when the radio is on. What connections am I cleaning?  ??? ??? (CCRT700)
TIA  ;)
Re: aerial/hrw
« Reply #1 on: 21 December 2011, 19:29:21 »
Start by gently cleaning the inside of the rear window - that normally helps mine when it goes a bit like sizzling bacon.
Hmmm, bacon....
Re: aerial/hrw
« Reply #2 on: 21 December 2011, 19:35:19 »
Hmmm, bacon....
isn't that a pink job?  ???  ;) ;) ;)
Re: aerial/hrw
« Reply #3 on: 22 December 2011, 00:08:01 »
No ::) sadly it's car related, which makes it firmly yours :D
Re: aerial/hrw
« Reply #4 on: 23 December 2011, 10:01:28 »
No body then .............  ??? ??? ??? ;)
Re: aerial/hrw
« Reply #5 on: 23 December 2011, 10:30:36 »
Either scratch on screen element, dodgy 0v connection for rear element/aerial or loose/corroded connections @ amplifier under parcel shelf
Re: aerial/hrw
« Reply #6 on: 23 December 2011, 11:19:14 »
Thanks Rob.  :y
I'll try & look later, just need to finish this ark first!!!  ???
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: aerial/hrw
« Reply #7 on: 23 December 2011, 11:44:34 »
Worth checking the old favourite of the aerial lead connector at the back of the radio - even if the connection is poor, it may still allow some signal giving the indication that it is ok, but the degraded signal from having the heater on may just be enough for it to show a fault
Radio & Decoding Technician
www.dndservices.co.uk
Re: aerial/hrw
« Reply #8 on: 23 December 2011, 11:59:34 »
Mmm! Good idea, as it's not that long back I had the radio out ................ back light bulbs for the centre console IIRC  :y :y
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Re: aerial/hrw
« Reply #9 on: 23 December 2011, 13:42:08 »
Had a a similar problem on the Carlton many years ago, turned out to be the aerial connection at the back of the radio.  But only after I had replaced the aerial amplifier and found it made no difference.  So if you need a 90378750 aerial amplifier, you're welcome to my spare  :y
I feel like a military academy. Bits of me keep passing out.
Re: aerial/hrw
« Reply #10 on: 23 December 2011, 14:33:11 »
Thanks, I'll bear that in mind. It'll not be this side of new year though when I look, and it's far too wet at the moment.  ;)
Humpy
  • Tunbridge Wells, Kent
Re: aerial/hrw
« Reply #11 on: 23 December 2011, 23:16:53 »
I got fed up with the HRW aerial and fitted a roof aerial. A bit fiddly but superb reception now. My car is an estate but swmbo's car is a saloon and the reception is fine!
Humpy
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: aerial/hrw
« Reply #12 on: 30 December 2011, 12:34:42 »
Best solution by far !!
Re: aerial/hrw
« Reply #13 on: 30 December 2011, 12:43:56 »
So ......... what are my options if I wanted to go the same route? Not sure what my roof aerial already does   :-\ :-\ :-\
Humpy
Re: aerial/hrw
« Reply #14 on: 31 December 2011, 16:59:48 »
I fitted a Hirschman (correct spelling?) whip aerial on the roof between the sunroof and the windscreen. It's the type of aerial that Peugeot and Renault use so you may be able to get on from a scrappy (about a two foot whip on a hinged mount). Carefully release the plastic trim which houses the sunroof switch/interior light which allows you to see the interior of the roof. Drill the hole, carefully, and taking care that the hole is in the middle of the roof (left to right wise, obvious really but...!) and the hole is about midway between the windscreen and sunroof. Make sure that there's nothing in the way underneath where you intend to drill the hole! Remove the near side door pillar trim and using a peice of stiff wire, fish the aerial cable across the roof lining. Remove the glove box and poke the aerial cable down the side of the dashboard moulding. Fish the cable out from behind the glove box and once the radio and cage is removed poke the cable round behind the heater controls and out of the radio apeture. Simples! Took me about an hour to do thats all and I get superb radio reception.
Humpy
PS The wifes car is a saloon and has excellent reception with the standard setup!
