Author Topic: leads  (Read 2586 times)
Damo1983
  • bolton greater manchester
    • omega 2.5 v6
leads
« on: 23 December 2011, 09:01:35 »
hello i previously bought a 2.5 v6 omega auto and had problems with it misfiring i changed all plugs last night and found that some of the leads were tracking does any body know how to change leads
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: leads
« Reply #1 on: 23 December 2011, 10:03:14 »
The dis-pack (combined coil and electronic distributor) is at the back of the N/S cylinder head and a bit of a PITA to get at, but removing the scuttle from under the windscreen makes access a bit better (you have to remove the wiper arms to get it off though) removing the upper inlet plenum also helps.
As always... replace the leads one at a time so you don't get them muddled up.
Here is the guide for changing the dis-pack which may be a little help..
http://www.omegaowners.com/forum/index.php?topic=90602.msg1155503#msg1155503
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: leads
« Reply #2 on: 23 December 2011, 10:32:16 »
From memory you can change the leads without taking anything else off, its a bit of a fiddle though.  Most important, as already said, do the leads one at a time, because you cannot see which lead goes where on the coil pack, you have to do it by feel.
Alan
Damo1983
    • omega 2.5 v6
Re: leads
« Reply #3 on: 23 December 2011, 10:36:47 »
Thank you both for this i will be trying it next week have to try and find leads as cheap as i can
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: leads
« Reply #4 on: 23 December 2011, 10:49:47 »
Try these  :y
http://myworld.ebay.co.uk/ajcompltd
Good fit and finish
Iirc, I only paid about 20 quid delivered  :y
