Author Topic: Got a couple of codes.  (Read 2284 times)
« on: 27 December 2011, 12:45:33 »
At work today and pretty bored,so decided to read the codes - if any present.
Got Airbag 44 - telltale signal low or circuit open
And - Climate control 56 - air quality sensor open circuit.
Ivw cleared them and will read them again tomorrow,but am curious as to what exactly they indicate,especially if they return. :-\
Re: Got a couple of codes.
« Reply #1 on: 27 December 2011, 18:48:39 »
SRS light OK?
« Reply #2 on: 27 December 2011, 18:53:17 »
Yep fine.It was on at one point so maybe I forgot to clear the code at the time when I turned the light off.Will check it again after driving the car for a few miles and see if its still clear. :y
« Reply #3 on: 28 December 2011, 11:33:20 »
Had ign on with dash out at some point, or battery went low.
Polution sensor was not detected by ECC at some point.
See what comes back.
« Reply #4 on: 31 December 2011, 17:30:10 »
Checked again today. 44 has disappeared. 56 has come back. Also got 19 and 121 (anti theft device codes). Connected to power sounder having been removed,or something unrelated ? :-\
ScaniaV8
  • Luton, Bedfordshire
« Reply #5 on: 03 January 2012, 14:37:22 »
I thought code 19 was indicative of maybe Crankshaft sensor related problem? or am I wrong??  :y
« Reply #6 on: 03 January 2012, 14:43:08 »
When reading the engine ECU codes yes. This was a code reader reading codes from other ECU,s.Its also possible that I wrote down the wrong number. :-\
