Author Topic: Oil Filler Seal  (Read 1837 times)
MikeDundee
  • Costa Del Peckham
Oil Filler Seal
« on: 29 December 2011, 08:06:12 »
Does anyone know the part number for the seal/rubber that fits the oil filler neck where it connects to the cam cover, think mine is gone as leaking oil.
Re: Oil Filler Seal
« Reply #1 on: 29 December 2011, 09:32:55 »
Not offhand, but always been given right one when I've bought one :)
In the meantime, remove filler neck, and put yellow cap directly on cam cover :y
Re: Oil Filler Seal
« Reply #2 on: 29 December 2011, 15:56:20 »
Its a big o-ring - as a temp solution try swapping the one on the oil cap with the leaking one - they are both the same size/part no.
Re: Oil Filler Seal
« Reply #3 on: 29 December 2011, 16:00:06 »
Wont that transfer the leak to the oil cap ?  ;)
Re: Oil Filler Seal
« Reply #4 on: 29 December 2011, 16:16:28 »
Yes, but less extreme.
But removing the neck altogether until new part available is a fix ;)
Re: Oil Filler Seal
« Reply #5 on: 29 December 2011, 16:19:12 »
Yup. :y
Re: Oil Filler Seal
« Reply #6 on: 29 December 2011, 16:20:04 »
I managed to drive all the way to Vauxhall (about five miles) without a filler cap at all and no leaks.. Ahem  :-[ :-[
MikeDundee
  • Costa Del Peckham
Re: Oil Filler Seal
« Reply #7 on: 29 December 2011, 16:20:55 »
Not a problem, I have a spare oil cap so will change the seal over :y
