Author Topic: Its never ending  (Read 2825 times)
Re: Its never ending
« Reply #15 on: 29 December 2011, 11:31:06 »
aren't cooker circuits normally 32A
yup minimum 32amp depending on size of cable going to it, hopefully 6mm minimum cable size  :y
Yup, std 6mm 7 strand. Sure the trip is a 32 though.  Consumer unit a bit of a sod to get to, but will double check next time I'm dragging junk out of the cupboard ;D
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #16 on: 29 December 2011, 11:37:23 »
It may have been failing for a while, but Christmas Day is probably the only day of the year when both ovens are on, along with all 4 hobs, pulling probably nigh on 45A
i hope that statement isnt implying that your dishwasher is on the same circuit as your cooker ??
the cooker should be a seperate circuit and dishwasher on with kitchen general ring or its own circuit  :y
« Reply #17 on: 29 December 2011, 11:39:52 »
Cooker is on its own dedicated circuit, as it should be (excluding the 13A socket that is part of the cooker switch, this is also obviously on cooker circuit).
Not sure what dishwasher is on, guess the kitchen ring main, never bothered to check ;D
« Reply #18 on: 29 December 2011, 11:41:02 »
All I know is Bosch, Siemens, Neff are the same company, since we had a small issue with a neff oven replaced under warranty with a siemens, they just charge progressively more for each name. Not aware of any other brands involved tbh.  :-\
Repair men are out here too. Clumsy eejits and too expensive to get to the door.
fiend61
  • york
  • each to their own
« Reply #19 on: 29 December 2011, 11:41:46 »
esp considering how most sparks fit these things
hmmm didnt pick up on this before,   dont tar all sparkies with the same brush mate  :o  :y
thats ok then  :y
« Reply #20 on: 29 December 2011, 11:51:45 »
I did say most ;)
This house was a new build when we bought it, and I suspect the brummie spark Redrow got in to do it was paid thruppence for each house, thus speed was more important than quality.
I was here when he did most of the 1st fit, as I was running in a few reels of Cat5, he seemed a good lad, but the quality of the sockets in particular is the cheapest of the trade shite. Had to change a few now, got a couple more that can't be turned off, so need to replace them when I pull various units out.  OOF server hangs off one of the knackered ones, but as thats always on, no hurry.
I come from a family of sparks, so know how to do things, even if it takes a few minutes longer to do it right...  ...but its usually easier to ring up my little bro, and get him over if its a few bits that need doing (he lives near Newmarket, so not exactly round the corner!) ::)
« Reply #21 on: 29 December 2011, 11:55:51 »
So when did Tunnie brake down then. ;D
« Reply #22 on: 29 December 2011, 17:08:15 »
I have a two repair limit on most appliances. If it brakes again, out to pasture. Usually because by the time you've forked out on said two repairs and buggered about sourcing parts, down time, and possibly broken or found other faults while in there, could have bought a new for the same money.
Get a new one J. Our Bosch has been good as gold.
This is its 3rd repair, although I think the 1st two were the same (if you recall, in the summer, I failed to find fault, and it started working after I got back from hols).
But seeing as all home appliances are the result of extreme penny pinching, slowly you end up fixing all the shortcuts the manufacturer has taken.
Don't Bosch and Hotpoint come off the same lines, or has that changed since Indeshit took them over?
I believe this one is actually still under parts warranty, but you cop the labour charge, which is extreme (I guess to cover parts cost ::)), and in my experience of most home appliance repair people, its better to just do it yourself.
For dishawashers, yes.
Its not so obvious these days as it was when the Ultima's were made, the only difference then was a few extra curves on the Hotpoint (with the Bosch being standard crout square shaped).
I would not buy a Bosch if our oven is anythin to go by though!
Taxi_Driver
« Reply #23 on: 29 December 2011, 17:37:32 »
I guess it depends on 'todays' build standard.....i went thro a little phase of buying bosch appliances......dishwasher....15yo  packed up last year....used nearly every day....i decided on a new one, rather than get it repaired.....a cheapo indesit....i shall see how long that lasts.
Washing machine, also Bosch, also about 15years old......used 3 to 4 times a week.....still going, tho i did replace a noisy pump motor a few years ago....
Oh and my parents have a bosch dishwasher, same model as mine was, same age....and still going....however it only gets an outing one or twice a week.
