Arghhh! Need some advice!
Started by D, 31 December 2011, 17:28:48
Quote from: D on 31 December 2011, 21:47:00
Just read this, not sure I want to fry anything yet:
http://www.bba-reman.com/forums/Topic56772-2-1.aspx
Might have a browse through the user manual. If I can unlock the bloody thing.
Doesn't look anything special to me, just alternator output voltage controlled by the ECU. Plenty of cars do that these days.
Either get a decent mains battery charger and give it an overnight charge or jump leads, IMHO. Most booster packs won't start a car with a properly flat battery IME, so don't rely on one of them.
Dave DND
You can usually get to a F*** starter motor +ve connection if you reach from underneath
Radio & Decoding Technician
www.dndservices.co.uk
Quote from: Dave DND on 01 January 2012, 19:17:42
Same as a V******* then  ;D ;D
D
I have to say I chickened out today. Just used the good old Elite instead. I had visions of fried circuits and exploding satnav screens all last night.  :o Might have been due to the wine though!
Will get some jump cables tomorrow and give it a go.
I don't think the Vx batteries are the same size. I need a 075, the Vx's seem to be bigger. Plus Halfords may be the only thing open tomorrow.
Remind me of sequence. Both cars off, recipient + to donor +, donor - to unpainted secure area in the recipient car. Start donor, wait a few mins and then crank up recipient.
After this can I disconnect whilst both cars are running or do I need to shut both down first? And is there an order to disconnect?
As it doesn't appear to be urgent, I would recommend taking the battery out and giving it an overnight charge on a mains charger. It'll be kinder to the battery than a jump start, but I can't see a problem with jump starting it.
D
Checked and the battery was producing 1.5V. Found a neighbour with a hefty booster pack, gave it a go and it fired to life. Thanks for all the advice chaps. I did have jump leads ready incase the booster pack did not work. Maybe time to invest in a battery charger/conditioner.
Quote from: D on 02 January 2012, 20:23:42
Checked and the battery was producing 1.5V. ....
How much?!?!  :o :o
