Pages: 1 [2] 3  All   Go Down
Author Topic: will 02 bodypanels fit onto 99  (Read 7021 times)
Autographix NI
  • Co Down N IRELAND
    • 99 Carbon Wrapped 2.5 td
Re: will 02 bodypanels fit onto 99
« Reply #15 on: 28 January 2012, 02:05:29 »
wings and door OK but i think the other bits need more work to make them fit
any more info on bonnet fitting , have the facelift car stripped gonna get all swopped on monday
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #16 on: 28 January 2012, 06:44:31 »
i take it that the 99 is a mfl with the window switches in the centre gearshift surround?  if so you would need the door loom out of your mfl to fit in the newer doors, as to fitting the the older doorpanels i think the door handles are in a slightly different position and the tweeters definitley are,
as for the bonnet that wont swap over as the grill is attatched to the bonnet on the newer one whereas the grill is attatched to top of bumper on the older one also the bonnet slam panel (where the bonnet clicks into) is slightly different, i am not saying that all this cant be done but you would have to swap door looms, cut out the bonnet slam panel and weld into the older car so you could fit bonnet and wings you would have to swap the headlights over too as they are slightly different aswell,  seems an awful lot of faffing around but as i said it can be done and has been done  :y
« Reply #17 on: 28 January 2012, 08:47:31 »
as for the bonnet that wont swap over as the grill is attatched to the bonnet on the newer one whereas the grill is attatched to top of bumper on the older one also the bonnet slam panel (where the bonnet clicks into) is slightly different, i am not saying that all this cant be done but  ....., cut out the bonnet slam panel and weld into the older car so you could fit bonnet and wings you would have to swap the headlights over too as they are slightly different aswell,  seems an awful lot of faffing around but as i said it can be done and has been done  :y
Bonnet is a straight forward swap as long as you fit the facelift bumper too, the slam panels are the same - no welding required. Obvioulsy headlights are different.
Autographix NI
  • Co Down N IRELAND
« Reply #18 on: 31 January 2012, 02:03:20 »
started into it today wings went on easy except for bolt on inside of wheel arch, front bumper cross members are different too still messing about with them had to extend wires going to washer bottle as really want new type bumper as am goin to wrap it & dont want black plastic bits on old type bumper showing, if bonnet goes straght on will be great , have doors on but as said am gonna have to change the looms over , just gonnna stick with old boot lid as no key hole in new type one dont fancy being locked out. have to new type tail lamps too dont know if they wil fit but early ones look better anyway . It is alot of messing about but wil be worth it in end cant wait to get it back on the road
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #19 on: 31 January 2012, 17:38:01 »
Looks nice, would like to see more pics of that!
I've been told if you change the bonnet and the bumper from the newer model, you need to change headlights too? but looking at the pics, they look the same imo
fiend61
  • york
  • each to their own
« Reply #20 on: 31 January 2012, 17:40:08 »
nope slightly different in shape  :y
Autographix NI
  • Co Down N IRELAND
« Reply #21 on: 02 February 2012, 01:56:24 »
here are a few pix from the other day
Autographix NI
  • Co Down N IRELAND
« Reply #22 on: 09 February 2012, 02:07:56 »
few more pix
Autographix NI
  • Co Down N IRELAND
« Reply #23 on: 18 February 2012, 06:31:52 »
carbon fibre
Autographix NI
  • Co Down N IRELAND
« Reply #24 on: 21 March 2012, 03:27:15 »
few more pix
MV6Danny
  • Swindon, Wiltshire
  • Driving at the speed of light
    • 99 irmscher mv6 3l Manual
« Reply #25 on: 22 March 2012, 01:38:08 »
That looks well cool  :o  I really like that :y Is it hard to do that and where would you get the wrap from? Is it expensive? Gotta be cheaper than a respray. Can you get a pearlescent colour that changes colour when the light hits from different angles?
Back in the MV6 again now
Autographix NI
  • Co Down N IRELAND
« Reply #26 on: 22 March 2012, 02:32:17 »
thanks , wel yes yes & yes you can get all from a company called MDP including flip paiant effect def cheaper than a respray , i run a small graphics company & this is what we are trying to get into owes me about £400
here is a link to the flip vinyl section
http://www.mdpsupplies.co.uk/vehiclewrappingvws4.asp
« Reply #27 on: 22 March 2012, 12:27:27 »
Just swop your engine & gearbox into the newer motor, job done :y
but prefacelift cars are nicer looking ............  ;) ;) ;)
;D
  + 1   :-X
Nice job your doing there Autographix  ;)
Autographix NI
  • Co Down N IRELAND
« Reply #28 on: 24 March 2012, 02:22:26 »
we did a fun rally for charity last week Formula cannonball newy to limerick via everywhere , heres us at the start
Autographix NI
  • Co Down N IRELAND
Pages: 1 [2] 3  All   Go Up
