Pages: [1] 2 3  All   Go Down
Author Topic: Rear spring change  (Read 4959 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Rear spring change
« on: 05 January 2012, 16:59:48 »
Not having done this earlier  :-[ I need to get it done now as the back is sagging a little with the lpg tank in the boot.  I dont want to upset the back as much as possible nor mess about with removing plates and dropping the diff etc.
I have some spring compressors and was wondering if anyone had managed to change the springs using these and not disturbing the big nasty stuff?
Re: Rear spring change
« Reply #1 on: 05 January 2012, 17:02:58 »
Not really enough room for compressors. If you don`t want to drop the diff you can always use a trolley jack and the car jack
« Reply #2 on: 05 January 2012, 17:03:31 »
I've replaced my rear springs on the 2.2 with LPG fitted, no issues...
Gaffers
« Reply #3 on: 05 January 2012, 17:40:52 »
Looks like plenty of room in there tbh  :-\
How easy were they to remove/replace with the car jack option?  I guess I could do one side at a time with that technique?
« Reply #4 on: 05 January 2012, 19:10:11 »
Honestly, dropping diff is the easiest way. No chance of compressors working, and suspension lacks the travel to move far enough for jack trick without overstressing some bushes somewhere.
« Reply #5 on: 05 January 2012, 20:01:28 »
No need to touch bush plates. As the guide, it is easy, and safest for you and the car.
« Reply #6 on: 06 January 2012, 01:31:25 »
Changed rear springs on saloon without dropping diff - used spring compressors - no issues, a bit awkward but went in ok.  HTH :y
amba
  • Medway towns
    • German V6
« Reply #7 on: 06 January 2012, 08:12:03 »
I tried the jack method and found it near on impossible to stop the bottom plate of the jack slipping off the curved surface.It also tends to distort the double walled metal part of the wheel arch. IMHO this method is not practical,although I am sure others would dissagree.
Very little room to get spring compressors in and be able to wind bolt to squash them down,so my money is on the dropping the diff as takes very little time and you can remove /replace the springs with total safety.
« Reply #8 on: 06 January 2012, 08:38:14 »
Its a sub one hour job by dropping the diff to do both sides so dead easy.
« Reply #9 on: 06 January 2012, 09:01:42 »
Yes, I would agree with that although I took slightly longer due to external factors - tea, phone calls and so on.
The guide provides all the information necessary to carry out a straightforward and uncomplicated change.
« Reply #10 on: 06 January 2012, 09:03:45 »
Also helps if you soak shock bolts, diff bolts & the brake line pins in WD or PlusGas few days before.  :y
Gaffers
« Reply #11 on: 09 January 2012, 19:55:06 »
No need to soak them Tunnie, I'm not a useless student/lanky streak of piss  ::) ;D
But, what a pig of a job!  Ok the lack of daylight didn't help but WFT!  Finally dropped the diff expecting it to go all the way down to the exhaust...but no!  It decided to stay just short of making it easy to pop the spring out  >:(
One head/towbar exchange, a gouge in the right wrist and battered hands later I get the diff dropped enough to manhandle the springs out.  They certainly did not just slip out as was implied in the guide  ::)
Was defo not catching on anything, a little pursuasion from the sissor jack eventually got me out of the poo    :y
Then again, I was probably just being a shit mechanic  ;D
« Reply #12 on: 09 January 2012, 19:56:51 »
Did you remember to take the handbrake off ::)
Gaffers
« Reply #13 on: 09 January 2012, 20:00:46 »
Yes fatty, and in neutral on the autobox too.  So ner  :P
« Reply #14 on: 09 January 2012, 20:02:39 »
I didn't. Twice  :-[
Pages: [1] 2 3  All   Go Up
