Author Topic: INJECTOR SEAL LINKING IN OMEGA 2.2L AUTO PETROL  (Read 4368 times)
Re: INJECTOR SEAL LINKING IN OMEGA 2.2L AUTO PETROL
« Reply #15 on: 08 January 2012, 22:09:37 »
Glad your well on the way to getting things sorted. If you need any more help,send me a message and I will try to help if I can. :y
I know English isnt your original tongue which may make things a bit difficult at times,but try to avoid using text speak words when posting as its somewhat frowned on. ;) :y
Example - thx instead of thanks. Not having a go by any means or trying to patronise,just offering a little advice. :y
« Reply #16 on: 08 January 2012, 22:18:19 »
Gibby has just asked me via PM about the location of the injector seal.I dont really know my way around the 4 pot engine and didnt want to give the obvious answer "bottom of injector", as Im not even sure what needs to be removed to access the injectors.
Anyone able to offer him some basic advice/info please ?
Edit. I have had a look at the LPG fron end install thread which clearly shows the injectors. Are they just a push fit into the manifold?
Is the seal just an O ring type seal ?
« Last Edit: 08 January 2012, 22:29:22 by Albs »
« Reply #17 on: 09 January 2012, 17:37:42 »
I'm struggling to remember what type of injector the 2.2 has. :-\
There's a cable tray which has the connectors to the injectors built onto the bottom of it, so that needs to come off and be moved aside. I believe the injectors are the end-fed type (like the V6) that sit between the rail and the manifold rather than side-fed injectors that sit inside the fuel rail.
If I'm right then the injectors are clamped between the fuel rail and the manifold, so unscrew and withdraw the fuel rail, carefully easing the seals out of the manifold, and you will find the injectors clipped to the fuel rail.
MOT fail will be down to one of the seals between injector and fuel rail, most likely, as these result in a fuel leak whereas the lower seals will give you an air leak.
Probably worth getting hold of a complete set of seals, or at least a handful, in case you damage any during removal or find that more than one have failed.
I find it handy when reassembling to clean the seats in the fuel rail and manifold of any crud and corrosion and then giving them a light greasing to allow the seals to slide in easily and avoid them getting damaged.
They are just generic seals for Bosch 0280155 series injectors so if they are expensive from a main dealer you can probably pick up a pack from any fuel system specialist, or ebay, pretty cheap.
« Reply #18 on: 09 January 2012, 17:48:57 »
Very helpful (as always) Kevin,thanks.I will make sure the OP reads this and try to ensure he gets the correct parts. Hes not far from me so I will have tools etc. if he needs them. :y
gibby
  • braintree
« Reply #19 on: 09 January 2012, 18:52:02 »
hello sir, hope you're fine. good news early in the morning I went straight on the car and started working on it. I indeed found a very easy job I removed the injectors and no. 4 cylinder seal was badly damaged. I tried to look around the shops but there was none. But a delivery van drive gave me a phone number of T&M the injector dealers who sold me 8 of the seals at £8.50. So I changed all of them. Now the sound has stopped and the car is running smoothly, and I will take it  for MOT tomorrow.
I like to take this opportunity to thank you and all the people like Kelvin who trired their best to help me, thank you very much. gibby
gibby
  • braintree
« Reply #20 on: 09 January 2012, 18:52:42 »
« Reply #21 on: 09 January 2012, 18:56:44 »
Excellent news Gibby. :y If you have any further issues give me a shout. :y
gibby
  • braintree
« Reply #22 on: 09 January 2012, 19:44:56 »
thanks very much sir, I will definitely do so.
gibby
  • braintree
« Reply #23 on: 09 January 2012, 19:45:56 »
