Author Topic: Air/con  (Read 1073 times)
Air/con
« on: 06 January 2012, 21:50:11 »
Hi all , so my air con rad has seen better days as its all falling to bits at the bottom edge ...i have taken the engine cooling rad out for replacement and only just discovered the condenser rad is no good . Now im not bothered about air con and was considering not replacing the condenser BUT could i take the condenser out and all the plumbing without causing any issues with the car ..
Thanks  :y
Re: Air/con
« Reply #1 on: 06 January 2012, 21:52:49 »
Yup as long as the aircon relay stays in
Re: Air/con
« Reply #2 on: 06 January 2012, 21:56:36 »
Thats good news .... save me getting a new condenser and re-gas , i know the cooling rad will be more exposed to the elements stones and stuff but planning to but extra mesh where the condenser sits  :y
Re: Air/con
« Reply #3 on: 07 January 2012, 10:01:25 »
Mmm made me think ...where`s the relay so as not to remove by mistake . So it wont affect anything with also removing the 2 fans that are attatched to the condenser or do these need to be fixed to the engine cooling rad . Just about to start to remove the condenser so will go by advice  :y
