Author Topic: curtousey light  (Read 8024 times)
greenman
  • greenock
curtousey light
« on: 08 January 2012, 11:41:02 »
Lights above the mirror don,t come on when the door is opened.Puddle lights do.They work with the switch.Any thoughts?
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
Re: curtousey light
« Reply #1 on: 08 January 2012, 13:42:57 »
hi
could be the bulb  check or change it and go from there :)
long live the magic tree
its good to be back
greenman
  • greenock
Re: curtousey light
« Reply #2 on: 08 January 2012, 14:56:29 »
Not the bulbs light works off the switch
Re: curtousey light
« Reply #3 on: 08 January 2012, 15:04:24 »
Does it illuminate when pass. door is opened?
greenman
  • greenock
Re: curtousey light
« Reply #4 on: 08 January 2012, 17:47:03 »
Doesn.t with both doors.Can,t be the switch because the puddle lights work.
  • Auckland
    • Mazda MPV
Re: courtesy light
« Reply #5 on: 08 January 2012, 19:34:07 »
My recollection is that the puddle lights switch off as soon as the doors shut but there is a time delay on the centre courtesy light that dims the lamp before it switches off.
Don't know if there is a separate fuse for the time delay  :-\ I don't have the wiring diagram in front of me to check.
My plan would be to track down the time delay module (sorry, I don't know where it is) and go from there.
I assume that you have standard bulbs fitted (not LEDs).............
  • Auckland
    • Mazda MPV
Re: courtesy light
« Reply #6 on: 08 January 2012, 19:36:02 »
PS the map reading lights only work when the engine is running.
Re: courtesy light
« Reply #7 on: 08 January 2012, 19:43:01 »
Ignition is on
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: curtousey light
« Reply #8 on: 08 January 2012, 21:10:50 »
I think im in the same boat as greenman, my interior lights were working (as always never happy with what I had) changed with Led's. They worked but noticed when locking the car they didnt completely go off. So changed back to the same normal bulbs but both map reading/interior lights don't work?? All fuses seem fine ???.
Sorry to hijack the thread  :y
greenman
  • greenock
Re: curtousey light
« Reply #9 on: 08 January 2012, 22:20:38 »
Fuses OK.Are the map lights and courtesy lights the same bulbs as map lights work OK p.s. not LED,s
greenman
  • greenock
Re: curtousey light
« Reply #10 on: 08 January 2012, 23:10:08 »
As above plus is there a "how to" remove the interior light(facelift).Had a look but can,t find one.Also if there is a relay anyone know where?
Re: curtousey light
« Reply #11 on: 08 January 2012, 23:15:36 »
If memory serves .. the interior lights, as against the map lights, go through a "time delay relay" ... they stay on for a while, then dim and extinguish, unless you lock the car when they go out instantly ....  where that relay is I don't know .. :(
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: curtousey light
« Reply #12 on: 09 January 2012, 00:06:22 »
I've recently changed mine to LEDs, and found that happened too. Fortunately, I had 2 different types of LED, and swapping them around made everything work properly.
They are a big improvement over the originals; they illuminate right down into the footwells which is something the originals never did.
amba
  • Medway towns
    • German V6
Re: curtousey light
« Reply #13 on: 09 January 2012, 07:38:22 »
Where did you get the LED ,s from the NickW ?
The quality of the interior light has been a constant issue for me since day 1 :'( as I often do paperwork etc in car and have ended up buying a clip on LED for the dash but would much prefer just the light to be better. :y
greenman
  • greenock
Re: curtousey light
« Reply #14 on: 09 January 2012, 12:48:32 »
Checking fuses(again) white relay 024433182 left of fuses now making fast beeping noise when the key is in position 1 ignition on beeping stops.Any ideas what this relay is for?
