Author Topic: heater problem  (Read 1488 times)
reinholds123
heater problem
« on: 08 January 2012, 13:31:43 »
Why A/C fans working all time?
Re: heater problem
« Reply #1 on: 08 January 2012, 13:37:25 »
Do they keep running with A/C switched off?
reinholds123
Re: heater problem
« Reply #2 on: 08 January 2012, 13:41:04 »
if i switch all heater off then they stop working bu if is on they work all time. its all the time on HI. and engin tem. lower than 80
tango
  • brum
Re: heater problem
« Reply #3 on: 09 January 2012, 08:01:44 »
Have you tried resetting the heater controls
Don't know if it'll make any difference
Re: heater problem
« Reply #4 on: 09 January 2012, 09:19:36 »
If you're talking about the fans in front of the radiator then yes, they work all the time when the air conditioning is on (or climate panel not in "ECO" mode). This is normal. It's because a stream of cold air over the condenser (in front of the radiator) is required for the air conditioning to work effectively.
