Pages: [1] 2 3  All   Go Down
Author Topic: Aux belt tensioner 3.0 elite  (Read 4713 times)
« on: 08 January 2012, 15:24:32 »
Hi, looking at replacing my aux tensioner/and belt today as it looks fairly old and cracking in places ..question is where is the tensioner and how do you access it , i have all the rads out and pipes from air con removed to make things easier  :y
« Last Edit: 08 January 2012, 15:32:34 by eatmydust »
RobseyMV6
  • west sussex
Re: Aux belt tensioner 3.0 elite
« Reply #1 on: 08 January 2012, 15:33:41 »
15mm socket on aux tensioner nut and turn clock wise to lossen belt  :y
to replace tensioner pulley undo nut and take off, then replace and do up again.
« Last Edit: 08 January 2012, 15:35:22 by RobseyMV6 »
« Reply #2 on: 08 January 2012, 15:34:20 »
top left pulley is tensioner for aux. 15mm spanner, rotate clockwise to move it to slanken belt for removal
« Reply #3 on: 08 January 2012, 15:36:41 »
I can see the pulley/tensioner wheel , so is the nut adjuster located at the side ...looks like very awkward access ?
« Reply #4 on: 08 January 2012, 15:37:51 »
I can see the pulley wheel , so is the nut adjuster located at the side ...looks like very awkward access ?
Its spring loaded, so no 'adjustment', as fully automatic. 15mm clockwise pushes against spring, allowing belt removal
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #5 on: 08 January 2012, 15:38:38 »
in the middle of the pulley, the whole pulley moves. :y
« Reply #6 on: 08 January 2012, 15:41:09 »
:y :y :y.....Arr i see , the bolt is inside centrally of the pulley wheel  :)
The Red Baron
« Reply #7 on: 08 January 2012, 15:43:06 »
yes, put your 15mm spanner on it & turn clockwise, as if you tightening it up, the pulley wheel will move to the right allowing you to remove the belt.
« Reply #8 on: 08 January 2012, 15:50:00 »
Got it ....Had a pully shatter on my last 3.0 and the belt wrapped itself in some most unusual places , left me stranded on the M1  :( someone i knew replaced the belt but couldnt remember how he slackened the belt off .
Thanks all  :y
The Red Baron
« Reply #9 on: 08 January 2012, 15:54:34 »
Thanks all  :y
when fitting the new belt, put over the tensioner pulley 1st, then slide it over the waterpump pulley last as its smooth & it will slide over easier. :y
jon
« Reply #10 on: 08 January 2012, 16:05:02 »
Will do  :y while looking at the state of the aux belt im wondering when the cambelt was last done ??? I know it was done at 80000 but the car has done 40000 more since . Does the plenum have to come off to remove the cambelt plastic cover ?
« Last Edit: 08 January 2012, 16:12:44 by eatmydust »
The Red Baron
« Reply #11 on: 08 January 2012, 16:17:04 »
belt & tensioners need replacing then, change waterpump while you at it.
plenum comes off, yes.
« Reply #12 on: 08 January 2012, 16:23:42 »
Might as well while its all apart , i was thinking when the new rad comes tomorrow just to put it all back together but the cambelt condition would be on my mind ... will enquire how much a kit and pump is and sort it out  :y
The Red Baron
« Reply #13 on: 08 January 2012, 16:26:47 »
have a look at www.vauxhallworldparts.com
they sometimes have a good deal on gates kits. :y
« Last Edit: 08 January 2012, 16:30:37 by The Red Baron »
« Reply #14 on: 08 January 2012, 18:40:37 »
This one on ebay i found   http://www.ebay.co.uk/itm/Timing-Cam-Belt-Kit-VAUXHALL-/300640813274?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AOmega&hash=item45ff96c0da
Not a bad price but ill ask in the local car acc shop if they can do any cheaper ...think its about £23 for a water pump  ???
Pages: [1] 2 3  All   Go Up
