Pages: 1 2 [3]  All   Go Down
Author Topic: Aux belt tensioner 3.0 elite  (Read 4714 times)
Re: Aux belt tensioner 3.0 elite
« Reply #30 on: 13 January 2012, 14:44:48 »
Ok update : local acc shop has just rang back quoting £90 !!!!!!! for just the pulley  :o :o :o :o
£20 for the belt .      Having a laugh aint they  :-\
« Reply #31 on: 13 January 2012, 15:21:52 »
   6PK1900  £16 for the fan belt off ebay  http://www.ebay.co.uk/itm/Auxillary-Alternator-Drive-Fan-Belt-6PK1900-VAUXHALL-/380396566253?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item589166f6ed
No way paying £90 for the pulley , i can get the tensioner and pulley and belt for nearly half what the shop are quoting me for the pulley alone  , from ebay and thats with free delivery  ??? . Makes you wonder am i being ripped off ....by local acc shop  >:( >:(
« Reply #32 on: 14 January 2012, 00:35:45 »
Belt for V6 - £19  from Vx on TC
Pulley from Vx on TC - £24 last time I bought one.
« Last Edit: 14 January 2012, 00:37:53 by dbug »
« Reply #33 on: 14 January 2012, 19:55:25 »
£90 for the pulley only form acc shop so they can stick it  >:( Ive checked the pulley and it seems ok , all intact and bearing sound so im just going to replace the belt on its own...Tensioner is working correctly but couldnt find the lube tabs as its still on the car and seems almost impossible to access unless my hands were half the size  :-\ :-\ :-\
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #34 on: 14 January 2012, 20:00:34 »
for the time it takes, undo the 15mm nut in the middle, take the pulley off(only the wheel) pop the red/brown plastic rings out & pack with grease. its realy so easy to do. :y
« Reply #35 on: 14 January 2012, 20:05:48 »
Oh i didnt realise there was plastic rings that were removable , but thats on the pulley wheel like you say . Is it possable to lubricate the actual tensioner or is that a sealed unit  :-\
The Red Baron
« Reply #36 on: 14 January 2012, 20:09:01 »
you shouldnt need to, its a spring loaded jobby. just make sure the pulley is greased.  :y
« Reply #37 on: 14 January 2012, 20:16:56 »
Will do thanks for the info  :y :y
The Red Baron
« Reply #38 on: 14 January 2012, 20:23:16 »
your welcome.  :y
Pages: 1 2 [3]  All   Go Up
