Author Topic: Engine light with electric has came on  (Read 2157 times)
Latchie_3.0v6
  • OMAGH N.IRELAND
    • Omega 3.0 v6 elite (sold)
« on: 12 January 2012, 21:22:09 »
Just drive to shop and light came on. How do you do test to get the codes.
The only way forward is sideways
Latchie_3.0v6
  • OMAGH N.IRELAND
Re: Engine light with electric has came on
« Reply #2 on: 12 January 2012, 21:36:41 »
Coming up as 48
Battery voltage low
I only got new battery today. Was told it was the right one for the car
« Reply #3 on: 12 January 2012, 22:24:44 »
You can ignore that code, old one now fixed.  Any other codes?
Latchie_3.0v6
  • OMAGH N.IRELAND
« Reply #4 on: 12 January 2012, 23:06:18 »
What do you mean old one now fixed?
The code 4 flashes small gap 8 flashes then big gap and same again
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #5 on: 13 January 2012, 01:25:19 »
 I think what was meant is that your old battery is responsible for generating the code you read. In other words it is historic.
 With Tech 2 and probably lots of other code readers it is possible to " clear all codes" then see if it comes back. Not sure if this can be done using paper clip/ pedal trick, I have never used either.
« Reply #6 on: 14 January 2012, 11:44:10 »
After that repeats 3 times, what other codes?
