Author Topic: engine noise  (Read 2118 times)
Rikkor
engine noise
« on: 14 January 2012, 05:23:32 »
   The Omega has running more than 150,000miles already. well, feel the engine is more noisy than before although I know Omega's is always not quiet.
  any buddy knows about the anti-scuff agent stuff? any good reason to use it to make my omega a little bit quieter?
 cheers
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: engine noise
« Reply #1 on: 14 January 2012, 08:12:50 »
have you tried using wynns lifter treatment.Try doing an oil & filter change and add some wynns lifter treatment,also is the breather system clean. :y
also put your location,model and engine details in your profile as you dont say what engine you have and will help other readers diagnose any further posts ;)
« Last Edit: 14 January 2012, 08:17:58 by noel »
Rikkor
Re: engine noise
« Reply #2 on: 14 January 2012, 08:25:15 »
 sure .
  2.2 elegance, petrol yeah 03made
  will try that Wynn's
thanks
noel
  • frome somerset
Re: engine noise
« Reply #3 on: 14 January 2012, 08:28:01 »
seems to work on the on the v6's, takes a while to run round the system so don't expect immediate results  :y
« Last Edit: 14 January 2012, 08:29:41 by noel »
Rikkor
Re: engine noise
« Reply #4 on: 14 January 2012, 12:45:50 »
  will try to use one or two to see if there is any good effect.
 will update
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
Re: engine noise
« Reply #5 on: 14 January 2012, 13:59:54 »
i put some wynns in my 2.2 petrol and its got rid of the tapping from the lifters .worked a treat :)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: engine noise
« Reply #6 on: 14 January 2012, 15:10:52 »
 cheers
Rikkor, is it a Tapping Noise from the Lifters that you have, as I can't actually see where you have mentioned where the noise is coming from?
Rikkor
Re: engine noise
« Reply #7 on: 14 January 2012, 15:30:22 »
 the engine is quite noisy especially when the engine is at idling to 2500rpm. engine runs well but not that quiet than before.  looks like the noise is from the crankshift.
  I did engine overhaul 3 months ago
