Author Topic: Belt option  (Read 1450 times)
Belt option
« on: 14 January 2012, 14:55:43 »
Hi , having disabled my air con would it be ok to bypass the air con pulley using a belt designed for non air con or do i need to remove the air con pump in case the belt wont clear and fouls the pump pulley . Hope that explains what i mean  :y
1997 3.0 elite
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Belt option
« Reply #1 on: 14 January 2012, 14:58:18 »
1997 3.0 elite
That will be fine mate and has been done a few times to save expense :y
Re: Belt option
« Reply #2 on: 14 January 2012, 14:58:31 »
Use a 4-pot with A/C belt to bypass the V6 compressor
Re: Belt option
« Reply #3 on: 14 January 2012, 15:02:56 »
Arr thats good then , they ask me at the acc shop "is the car air con and power steering" so would i order the non air con for the V6 or as you say rob
4-pot with A/C belt
Re: Belt option
« Reply #4 on: 14 January 2012, 15:06:38 »
4-pot with A/C belt
Either, both do the job
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Belt option
« Reply #5 on: 14 January 2012, 15:07:08 »
To be honest I have never used a 4pot Belt which Rob is refering... I have however used for a V6 engine a None Air Con Belt which will just miss going around the Air Con Pump.
It does go around everything else. :y
Re: Belt option
« Reply #6 on: 14 January 2012, 15:10:53 »
Ok thanks to both ....will run the V6 non air con belt . Thought i would ask just to see if anyone had done that before without any problems of fouling .  :y :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Belt option
« Reply #7 on: 14 January 2012, 15:12:03 »
We Learn something everyday  :y
Re: Belt option
« Reply #8 on: 14 January 2012, 15:20:03 »
Yes ive learnt that its easier getting the aux belt off without all the air con pipes in the way ...the belt looked what you might say ok with general wear while looking at it in situ but when i pulled the belt off closer inspection shows bits worn away and cracking nearly all around the belt ...the belt has hardened quite bad as well  :o
