Author Topic: westfield q's  (Read 9432 times)
Re: westfield q's
« Reply #15 on: 18 January 2012, 21:14:57 »
Ah you'll fit fine most likely.. height isn't an issue in the Westy from what I know, it's erm 'girth' that's the issue. And I seem to be tipping the scales north of 28st at the moment :-/ At 16.5st you'll probably be just fine.
I think the Dax is wider than the Westfield - I don't know if Westfield do a 'widebody' version like Caterham, though.
I think they do :y.
Re: westfield q's
« Reply #16 on: 19 January 2012, 00:25:32 »
I think they do :y.
I think Westfield only do the wide version now. About the same size as the Caterham SV at a guess. Dax Rush is wider still, especially at the back. Something it pays to bear in mind when driving one IME.
A Dax might well be suitable for bigger engines as the engine bay is larger. It is also more steeply tapered towards the front so things could still be tight depending how far forward the engine sits. I don't find them as nimble but probably not as prone to be over-engined if you want big power.
X30XE fits in a Westfield nicely and is a whole world better than a Cologne and lighter to boot. Ditto the Ford Duratec V6. I think I'd have to live with one for a while before deciding I prefer it to a tuned 4 pot though. :-\
One thing to bear in mind is that you will be giving yourself a whole load of headaches if you go for an unconventional engine option, and along the way you'll probably discover why it's not a popular option. ;)
Re: westfield q's
« Reply #17 on: 19 January 2012, 10:01:13 »
What is the thinking here? Is it on one hand " I've just reshelled my MX5/Sierra" and on the other " I've just built a new car" with all that that implies... :-\
Not really such a clear-cut difference. You are building a car around a different chassis in both cases so effectively it's the same thing and both should end up registered afresh as a Westfield. When it comes to registration of the car, though, there are 3 possibilities:
1) You build a car with all new parts, and can prove their "newness". You'll get a new age-related plate just like any other new car.
2) You build a car using parts substantially from a single donor, and have the documents for the donor to prove it. You'll get an age-related plate of the year of the donor vehicle (sometimes they'll even let you take the donor's reg. no.).
3) You build a car using a mixed bag of new and used parts of various ages, or can't prove the age of all parts. You get a Q plate.
There are advantages with a Q plate in some respects in that you can get away with more than an age related vehicle at MOT. You can't transfer the number plate if you want a cherished plate, etc. though, and there is a little snobbery against them among some.
Also worth bearing in mind that the emissions testing criteria are based on the engine age so to avoid having to have a cat you need a pre-august 1995 engine with proof of age from memory.
That puts you into the MX5/Zetec/C20XE/Rover V8 territory. Maybe an early X30XE?
Of course, if you fuel inject it, having to have a cat is not a massive problem, but if fitting carbs it is. Also, there's no reason why you can't fit a newer engine once it's registered so you don't necessarily need a mint pre-95 engine. Just one that runs. ;)
I personally would prefer to go down the BIY route rather than a factory fresh one, purely for the satisfaction of doing it.
Fair enough. That was my take, too. ;)
Plenty of food for thought here, space will be the single biggest constraint I think. :-\
I built mine in a single garage with no problems at all They are small, especially before the bodywork, wheels and tyres are fitted.
I would try to see a few in the flesh, as that will give you a clearer view of the path that's right for you. Hoping mine will be back on the road soonish in which case it'll be along to a few meets. Failing that there are plenty of clubs who probably meet locally to you. Westfield Sports Car Club in particular springs to mind. http://www.wscc.co.uk/local.htm. I know there's a regular meet at Forest Green. Probably a few in Sussex too. Go along, kick some tyres, talk some bolax and blag a few rides... ;)
Re: westfield q's
« Reply #18 on: 19 January 2012, 18:07:22 »
I will say, having put a negative spin on it, on second reading, that building and owning it has been a great experience and, much like Omega ownership, has made me many new friends and given me a lot of fun wielding both the spanner, the steering wheel, and the pint glass. :y
And nothing more can beat that. It makes all the not-so-good days worthwhile.
I had some really down days with Project TB2/Tractor, but overall, my experience was nothing short of wonderful.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: westfield q's
« Reply #19 on: 19 January 2012, 18:36:56 »
Does that include a taste of my ham sandwiches? ;)
I like red cars
Re: westfield q's
« Reply #20 on: 19 January 2012, 18:42:01 »
Ah, yes, day one of Project TB2 :y
And it was cheese and ham ;)
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: westfield q's
« Reply #21 on: 19 January 2012, 18:44:16 »
I beg to differ :P
I like red cars
Re: westfield q's
« Reply #22 on: 20 January 2012, 00:15:33 »
Thanks for that :y Plenty to think on... :y
