Author Topic: Remote fob only half working?  (Read 7128 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 18 January 2012, 21:58:54 »
Started happening tonight can unlock but cant lock or open boot. Swapped battery ok,and I can hear the buttons clicking (even at my age), any thoughts. 2000 Elite.
Chris.
zirk
  • Epping Forest
Re: Remote fob only half working?
« Reply #1 on: 18 January 2012, 22:16:13 »
Just tried 2nd key, same deal.?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #2 on: 18 January 2012, 22:19:56 »
Sounds like its probably the motor or something then, if both keys are acting in the same way?
zirk
  • Epping Forest
« Reply #3 on: 18 January 2012, 22:22:42 »
Opens fine manually with the key so thinking not the motor, but thanks anyway.  :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #4 on: 18 January 2012, 22:28:57 »
Fair point actually  :-[
Just strange both keys acting up. Receiver?
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 18 January 2012, 22:32:18 »
Sorry, read the first post again. Is it only the boot that won't work with the fob?
zirk
  • Epping Forest
« Reply #6 on: 18 January 2012, 22:34:49 »
Im assuming reciever is ok as I can remote unlock, but lock or open boot with fob.
zirk
  • Epping Forest
« Reply #7 on: 18 January 2012, 22:37:08 »
Keep up jonny. ;D ;)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #8 on: 18 January 2012, 22:38:55 »
Ok, was just thinking there may be something trapped or obstructing the lock / mechanism, but not relevant now  :-\
Is it worth resyncing the fob? At least then you could rule that out?
zirk
  • Epping Forest
« Reply #9 on: 18 January 2012, 22:48:04 »
Yep, was slightly ahead of you there, just done that, same. >:( >:(
zirk
  • Epping Forest
« Reply #10 on: 19 January 2012, 12:52:03 »
Ok, sorted, neer knew they did that, if ts a design feature quiet clever really.
Something else Ive learnt today.  :-[
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #11 on: 19 January 2012, 13:15:18 »
What was it  :-\
twiglet
  • Norwich, Norfolk
« Reply #12 on: 19 January 2012, 13:23:09 »
something to do with the boot already being open I recon...  :-\
zirk
  • Epping Forest
« Reply #13 on: 19 January 2012, 13:24:42 »
What was it  :-\
Have a guess, I'll give you a clue, when you unlock the car and get in it warns you about something.
zirk
  • Epping Forest
« Reply #14 on: 19 January 2012, 13:25:42 »
Boot locked as normal.
