Author Topic: Auto box getting progressively worse.  (Read 2988 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 23 January 2012, 07:31:20 »
Posted up problems before about it holding gears too long.
Latest symptoms, after climbing a hill in first or second gear, takes several hundred yards before it changes up, on the flat or downhill.
Should add, only when engine is hot, OK when cold.
« Last Edit: 23 January 2012, 07:45:11 by Auto Addict »
I like red cars
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
Re: Auto box getting progressively worse.
« Reply #1 on: 23 January 2012, 08:32:39 »
This is a simalor problem I have with my car
holds on to third gear for a long time before it drops into four gear but only when hot ok when cold
Once it has done this it runs ok.
« Reply #2 on: 23 January 2012, 09:07:31 »
Service history?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 23 January 2012, 09:36:36 »
Service history?
About 74K, fluid changed @ 67K.
I like red cars
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 23 January 2012, 10:06:52 »
Service history?
Have you checked the fluid level again? It could quite easily be low, which would cause your symptoms.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #5 on: 23 January 2012, 11:45:48 »
Service history?
Fluid level is fine.
I like red cars
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #6 on: 23 January 2012, 13:15:54 »
Cam Sensor ?
I had one with similar probs for ages did all the usual until saw on here about cam sensor probs without codes.
Changed and cured, I was supprised  ::)
Phil
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #7 on: 23 January 2012, 13:54:38 »
Cam Sensor ?
Phil
Probably not, it's a 2.6.
I like red cars
« Reply #8 on: 23 January 2012, 14:10:50 »
Checked for codes recently?
« Reply #9 on: 23 January 2012, 14:37:52 »
Good point. If the gearbox is not changing smartly when commanded to by the ECU you will get incorrect ratio codes.
Can also watch the solenoids in live data with a tech 2 to confirm this.
Has the gearbox had the latest update?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #10 on: 23 January 2012, 16:14:28 »
No codes when last checked, gearbox has the latest update.
Can't remember if TB checked live data.
I like red cars
« Reply #11 on: 23 January 2012, 17:47:17 »
Have I seen this car recently :o. If I have, I don't remember it  :-[
Its a 2.6. Like all V6 DBW TCMs, its not as refined as non DBW, or indeed your old 2.2 - is it really a problem, or are you finding problems that don't exist?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #12 on: 23 January 2012, 17:56:22 »
As it's the same auto box as the 2.2, what's the difference?
I presume the ECU?
Any chance you could have another look at it please?
I like red cars
« Reply #13 on: 23 January 2012, 18:45:44 »
See if you can drive another 2.6 auto, so you know if you have got a fault
« Reply #14 on: 23 January 2012, 20:10:00 »
Suspected he was just being fussy tbh...  :-X  ;D
If shift quality is ok, no slipping and banging, then there can't be much wrong if no codes. My 3.2 does hang on to gears when sport mode is on. I guess just in case the driver boots it again.
Out of interest, exactly what rpm does it change up at on flat out acceleration...?
Page created in 0.026 seconds with 20 queries.
