My omega update pictures
Started by X3 OXE, 23 January 2012, 14:28:54
jordan681
One word...  MMMMMMMMMMMM
Now toffee me for being dumb.. But EGR and secondary air removed..   Err  please explain. Sounds like a mod I can do on mine
Always looking for a bargin..  PM me if u have any uprated Miggy parts...
X3 OXE
#16
You can buy a blanking plate for the EGR valve so it stays in the same place but is blanked. Which is how i use to have mine, but now ive made my own blanking plate on the plenum and moved the EGR under the battery out the way, it needs to remain plugged in so the ECU thinks its still working.
I used to have the secondary air injection removed and the manifold pipes blanked, but when i fitted the 3.2 exhaust manifolds it allowed me to remove the SAI altogether
Just tried to keep my intake temps as low as possible as the omega runs far to hot, the throttle bodie heater pipe removal is another good one. it warms the throttle bodie, which obviously raises the intake temps. so i blanked the waterbridge outlet and fitted a 2.5TD header tank without the throttle bodie heater pipe attachment
Removing the aircon is the best one by far though. the aircon rad and fans just block the coolent rad, when its all removed it gets airflow straight to the coolent rad. my temp gauge sits nice and low
And my second air feed is a 3" pipe cut into the bottom of the airbox, and ducting running to the front grill next to the original intake. So it gets all the air it needs and as cold as possible going into the engine.
I just want to redo the exhaust side of it next as im still running both CATS. and although the 3.2 manifolds are alot more free flowing, they are still very restrictive. So next im going to order the custom friedrich tubular manifolds and then go full custom exhaust from there back so it gets rid of the CATS as well
Should breathe perfectly then
Hope this helps a bit, Any questions just ask  :y
Quote from: nitro on 24 January 2012, 20:58:04
Yep,had that car sitting on my driveway for about 20mins and then Jay took it away  :'( :'( :'(
;D Will have to bring it round again so you can see the new look in the flesh. pictures never do it justice. Or got a little meet Sunday if your up for it mate  :)
Jason.
StuntS
That looks loverly! Gorgeous in white!
Shane mvsex
i want to go round some roundabouts in this beast  :y :y :y
migs and rc helicopters yeeeehaaaaaaa!
Www.omegaowners.com
Www.omegaownersnetwork.com
Reefpotato
  :y :y :y  Nice work M8, takes allot of time,effort and money to get one looking that nice  8) Well done, inspirational to us all to say the least  :y :y :y
Careful what you wish for, whoever's out there granting wishes sometimes has a strange sense of humour......
Andys VXR
Really love the car thats the look im going for great work mate .
X3 OXE
Thanks for the comments everyone :)
Jason.
QuoteTB Heater Pipes Removed (2.5TD Header Tank Fitted)
Another job for me to do  :y 2 jobs done not many more to catch up on  :D
Quote from: Reefpotato on 25 January 2012, 16:55:27
Just what i thought  :y
ferrymega
I'll tell it briefly : You're the most beautiful OMEGA I know !  :y
ferry
flyer 0712
that is some nice piece of kit matey  :y
kennny
I adore the wheels. Very nice car  :y
X3 OXE
Cheers guys,
1 more new picture,. just modified a strutbrace from Germany for left hand drive models as cant get strutbraces for uk omega's, bit of cut and welding on the drivers side bracket to make it clear the brake servo bottle an jobs a goodun! Just got to re paint the bracket red as had to rub it down for welding
Can also see the second air feed pipe from the grill for those that wanted a pic...
Jason.
kennny
Can i just ask what blanking off the egr valve does?
X3 OXE
Puts the exhaust gases into the inlet basically, so hotter intake temps and coats everything up over time. So blanking it will lower the intake temps and keep plenum an everything clean
Jason.
kennny
Sounds like something to look into doing on mine.
