Author Topic: Headlight removal  (Read 4247 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Headlight removal
« Reply #15 on: 31 January 2012, 22:58:55 »
 ;D ;D ;D ;D ;D ;D ;)
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« Reply #16 on: 01 February 2012, 03:35:22 »
I guess I was lucky to have been able to remove it without having to remove the bumper on mine then, just needed a bit of force and a long screw driver for a bit of leverage though. Mind you it did take me a few hours to change the xenon light bullb and re fit.
only reason why i had to change my headlights was because a main beam bulb blew & tryin to push new bulb into them poxi rather clips i managed to brake the headlight adjuster!! so a 5min job befor i went out turned in to a 2hour job because sum smart arse police mechanic!! had cable tied the washer jet pipes to the headlight & to bumper crash panel so bumper had to come off!!! so while off uprated the fogs to ice blue 80w bulbs  :y that saved my knuckles!!
farty_towels
  • Plymouth
  • Lively up yerself...!
    • MV6 Elite 3.0 2000
« Reply #17 on: 01 February 2012, 05:04:41 »
That's typical sods law isn't it!
Of all the things I've lost in life, its my mind I miss the most...!
« Reply #18 on: 01 February 2012, 20:12:50 »
PFL its easier to remove bumper if you have Elite or MV6.
Facelift, bumper can stay put.
« Reply #19 on: 01 February 2012, 20:23:56 »
Hhhwhyyyy?
« Reply #20 on: 01 February 2012, 20:26:34 »
Hhhwhyyyy?
The pfl headlight washers are bolted to underside of headlight, meaning not enough room between bumper and the metalwork above headlight to slide it out.
« Reply #21 on: 01 February 2012, 20:41:23 »
Hhhwhyyyy?
Ah, that's why I had no problems on my pfl cdx. No hids = no washers.
« Reply #22 on: 01 February 2012, 20:46:01 »
Hhhwhyyyy?
It is possible to unbolt washers in situ, but its far quicker and easier to pull the bumper off - 6 easy screws and 2 push clips :)
