Author Topic: plug leads  (Read 4176 times)
bored bigyin54
  • south wales
    • black beast
Re: plug leads
« Reply #15 on: 30 January 2012, 16:11:27 »
well webby its on its way to you now hope you get it sorted
Re: plug leads
« Reply #16 on: 30 January 2012, 16:49:41 »
nice little practice car Webby, you can now have a go at doing things safe in the knowledge your not going to break your pride and joy. Best way to learn  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: plug leads
« Reply #17 on: 01 February 2012, 20:48:39 »
Cheers all. Thanks to Ralf for working with me to get the car here; much appreciated  :y
Yep, jump started it today. Now obviously I'm no expert but I have watched vids of cars with cylinders out and it sounds the same.
Bit of smoke from back of the plenum but I suspect that's old oil from CC gasket (thanks, Albs  :y)
I am going to get the scuttle off and get to the back of the engine Saturday (and Sunday if it takes that long).
I have read the dis pack removal guide and understand it's numbered for ease of reference. Will I need to actually remove this to swap leads about if they're in the wrong place or will there be enough room to do it with dis pack still attached? Guide suggests taking it off (no problem for me as I have a weekend absence pass from SWMBO  ;D)
I understand the SP banks are...
             Windscreen
5                                       6
3                                       4
1                                       2
              Radiator
........so why on Earth (if I've got this right) does the diss pack go...
5                                       4
3                                       6
1                                       2
LOL!
RIP Paul Lovejoy
Re: plug leads
« Reply #18 on: 01 February 2012, 21:08:13 »
             Windscreen
5                                       6
3                                       4
1                                      2
              Radiator
5                                       4
3                                      6
1                                       2
LOL!
That`s where the mistake is made when re-fitting the passenger bank ;)
Webby the Bear
  • Northampton
Re: plug leads
« Reply #19 on: 01 February 2012, 21:09:33 »
Cheers Rob, I thought as much. Why are they like that though? lol to give mechanics in the know extra dosh when people make mistakes?  ::)
RIP Paul Lovejoy
Re: plug leads
« Reply #20 on: 01 February 2012, 21:15:45 »
;D
Webby the Bear
  • Northampton
Re: plug leads
« Reply #21 on: 01 February 2012, 21:26:49 »
Ok that brings me on to my next Q  ::)
Are the leads themselves numbered? So I can rule out wrong leads in wrong SP wells?
RIP Paul Lovejoy
Re: plug leads
« Reply #22 on: 01 February 2012, 21:30:09 »
Some have numbered "rings" on them, but if you`re removing plenum, shine a torch onto dis and you`ll see the plug numbers stamped on it
Webby the Bear
  • Northampton
Re: plug leads
« Reply #23 on: 01 February 2012, 21:32:08 »
Rings at the top of the ''tube'' that fits on the SP?
Cheers mate. I'm on it Saturday ;)
RIP Paul Lovejoy
bored bigyin54
  • south wales
    • black beast
Re: plug leads
« Reply #24 on: 01 February 2012, 21:36:08 »
if you can get it sorted webby you will have a good car before the cam cover change it only had a small miss fire which was oil contamination on plug leads which was con firmed so what he has done to it i dont know .because 2 days before it ran like a dream good luck steve  i think he wanted to make more money
« Last Edit: 01 February 2012, 21:43:16 by bigyin54 »
Re: plug leads
« Reply #25 on: 01 February 2012, 21:47:39 »
If numbered rings fitted they`ll be at the end of the lead just where it enters the actual cap
