Author Topic: light switch illumination  (Read 2950 times)
carts
  • west yorkshire
    • 2001, 3.2 elite
« on: 02 February 2012, 00:41:42 »
Have searched and read one or two posts about this and it seems there are two types of switch assemblies. Pre facelift and facelift types. can someone tell me how to improve the illumination to the switch symbols,(the white ones).If I remove the D shaped panel there is a T shaped black plastic bulb holder with a fairly feeble bulb secured inside it. Can I get a new one with a better bulb in it. Car is a 2001 3.2 elite Omega. If I have to go to vauxhall for it what is the part number.
Yorkshireman knocking on a bit.
Re: light switch illumination
« Reply #1 on: 02 February 2012, 08:48:18 »
That`s illumination for the heater vent, the switch itself needs to be removed and the bulb to be replaced is self-evident at rear of switch. Switch is held in by a metal sprung clip either side, may find it easier to push out from the rear with the "D" panel removed though be advised that only the switch comes out not the rear plug
carts
  • west yorkshire
    • 2001, 3.2 elite
« Reply #2 on: 02 February 2012, 09:34:12 »
Thank you for the info, Now it has been explained properly I understand. Will go and have a go at it.
« Reply #3 on: 02 February 2012, 09:37:59 »
Pic of spring clip
Where bulb fits
Pics of bulb, soldered in holder, 0.5W
carts
  • west yorkshire
    • 2001, 3.2 elite
« Reply #4 on: 02 February 2012, 12:06:16 »
Thanks RobG. I have already had the thing out and the bulb is working. I just thought the illumination was very poor, maybe thats how its supposed to be. Carts.
« Reply #5 on: 02 February 2012, 12:09:52 »
LED at the top of the switch inside may be blown
carts
  • west yorkshire
    • 2001, 3.2 elite
« Reply #6 on: 02 February 2012, 12:33:00 »
Wish you had told me before I reassembled the thing. How do you get inside to check. Tell me all you know about these things.CARTS
« Reply #7 on: 02 February 2012, 12:35:11 »
Gently prise apart
carts
  • west yorkshire
    • 2001, 3.2 elite
« Reply #8 on: 02 February 2012, 12:58:52 »
OK, any outher mouse traps I should know about. Sounds a bit of a crude way to me. How much is a new switch box if I knacker it.
« Reply #9 on: 02 February 2012, 13:02:46 »
Maybe, but that`s how they come apart. Replacement switch from a breaker, £10-15.
PS. Illumination will not be as bright as the dash lights or any of the other displays due to the 0.5W bulb
« Last Edit: 02 February 2012, 13:04:45 by RobG »
carts
  • west yorkshire
    • 2001, 3.2 elite
« Reply #10 on: 02 February 2012, 13:22:30 »
Hello again RobG, I will have another look at it but not today. Its too bloody cold here to be faffing about outside. Need door open wide as I`m not as young and agile as I used to be. Thanks again for all your help. Carts. who will be an octagenarion this year.
« Reply #11 on: 02 February 2012, 14:01:52 »
Glad to assist Victor :y
