Author Topic: Quick scuttle removal Q...  (Read 2305 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 03 February 2012, 23:34:11 »
Hi guys,
Been reading this guide...
http://www.omegaowners.com/forum/index.php?topic=90656.0
All makes sense but anyone know where the two clips are on the passenger side? I thought it was just remove wiper arms, remove 8 bolts and plastic trim along the engine bay and it would come out?
Cheers  :y
RIP Paul Lovejoy
Re: Quick scuttle removal Q...
« Reply #1 on: 03 February 2012, 23:41:47 »
Under the screen seal. Lift up the leading edge and work along until you find the clips. 90dgree turn with a flat blade screw driver, or the same Torx as the drivers side screw.
« Reply #2 on: 03 February 2012, 23:44:58 »
Nope, I got the wrong end of the stick. You mean the two metal clips that hold the polen filter section down? Under the rubber strip you pull off ...?
Webby the Bear
  • Northampton
« Reply #3 on: 03 February 2012, 23:47:22 »
Yes, that's what I was looking for  :y
To quote the guide...
''Then you have the a couple of clips holding the front part of the scuttle on the passenger side I removed these''.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #4 on: 03 February 2012, 23:48:39 »
...so as you've mentioned Chris, these are under the rubber that comes off in front of the pollen filter flap?  :y
RIP Paul Lovejoy
« Reply #5 on: 04 February 2012, 00:00:38 »
I don't remove them personally, just lever the scuttle around the clip leaving said clip in place. But each to their own. :)
Webby the Bear
  • Northampton
« Reply #6 on: 04 February 2012, 00:03:56 »
Nice one Chris. I'm sure it will become apparent anyway when I do it but did just want to double check  :y
RIP Paul Lovejoy
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #7 on: 04 February 2012, 00:15:04 »
Neither do I. Just be aware that the screen wash pipe and wiring is clipped to the join end. Scuttle will swing out of the way with these still connected.  :y
Regards
Alan
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #8 on: 04 February 2012, 10:23:30 »
best advice going when removing scuttle as if to try to remove the washer clips 99% of the time they will break  :(
yet another thing on the omega that gets brittle with age  :o  that includes the drivers  ;D ;D ;D
