Author Topic: Quick breather cleaning Q...  (Read 11008 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: Quick breather cleaning Q...
« Reply #15 on: 06 February 2012, 06:11:30 »
Plug leads. Blue ones are faster btw. :y :D
Ahhhhhh :y
AKA - Mr Bracket
« Reply #16 on: 06 February 2012, 13:44:38 »
@RobG, I take it the box in your pic is worth removing and cleaning inside when doing the breathers ?? Or is that just overkill ?
Thanks
Wouldnt be a bad idea to remove it to clean it - in theory. Istr its a pig of a thing to remove though. :-\
Webby - breather box isnt anywhere near as bad to get to as the dispack is. ;)
You aint kidding about that  :-\
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #17 on: 09 February 2012, 13:46:46 »
Sorry guys, just a quickie....
I have just been home for my lunch and decided to have a quick go at cleaning the breather bridge, TB, plenum etc. It;s going to be harder than it looks as it's proper caked on but I'm getting Carb Cleaner supplies bought for me by mummy webb.
However, the breather bridge all cleaned up no problem... I used a small drill bit to get the crud out and all ''looks'' great from the outside. But when I poked my drill bit down the 4 pipes, 3 are clear and allowed pasage for the bit and one wouldnt budge after an inch. Also the two bigger pipes at the front of the breather bridge are also stuck about an inch down.
should they be like this or is this just crud stopping it?
cheers
RIP Paul Lovejoy
« Reply #18 on: 09 February 2012, 14:06:34 »
No they should not be like that , take all the pipes off and soak them in cleaner / make sure they are completely clear one end to the other  :y
Webby the Bear
  • Northampton
« Reply #19 on: 09 February 2012, 14:08:15 »
Leeeeeegend ;) cheers mate  ;)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #20 on: 09 February 2012, 14:09:20 »
ps we are talking about the ones that are attached to the long black rectangle of plastic that has the ''eco tec'' usually on top? :)
RIP Paul Lovejoy
« Reply #21 on: 09 February 2012, 14:59:27 »
Yes,they are part of the breather system and need all the crap cleaning out.Just been finishing off doing the same thing on project CDX. ended up getting a shallow tray filled with petrol and leaving the breather bridge in there to soak.Then blew down the pipes,stuck a length of small bore plastic pipe down there and wiggled it about,soaked it again,blew down it again...........
Couldnt believe the amount of shite that came out considering I had already cleaned them in the usual way a couple of days ago.The petrol ended up a darkish brown colour with lots of lumpy bits in.Now tipped it out of the tray and theres a thick layer of sediment in the bottom of the tray.
Spend a bit of time on it Webby,you may be surprised at the amount of crud which comes out,depending on how well it has or hasnt benn done in the past.
If everything is really scummy I would recommend using petrol initially to shift the worst of it before wasting lots of cans of carb cleaner. :y
Webby the Bear
  • Northampton
« Reply #22 on: 09 February 2012, 15:03:29 »
i will do cheers albs :):):) thanks for all the info  :y :y
RIP Paul Lovejoy
« Reply #23 on: 09 February 2012, 15:07:15 »
If they are blocked , suprised if the rocker gaskets aint blown or have they just recently been done ? Must of been weazin like a good un . Check the plug wells  ;)
Webby the Bear
  • Northampton
« Reply #24 on: 09 February 2012, 15:59:02 »
Yes mate, recently done ;)
there's a tiny bit of oil in the plug wells. ill clean this and then see if there's any more being produced after just to double check the gaskets aint still leaking  :y :y
RIP Paul Lovejoy
« Reply #25 on: 09 February 2012, 16:04:20 »
Small amount in mine too , think it was from last blown gasket "monitor for sure"  ;)
Webby the Bear
  • Northampton
« Reply #26 on: 09 February 2012, 16:15:14 »
cheers EMD. Yeah when i first started it up there was a bit of smoke. i think there's lots of places where oil has fell on to!
i will take your advice and monitor very carefully  :y
RIP Paul Lovejoy
bored bigyin54
  • south wales
    • black beast
« Reply #27 on: 09 February 2012, 16:19:45 »
the so called vx cowboy must have made a right mess of it as i can see from the work you got to do steve :y :y :y :y sorry mate
blackviper90210
« Reply #28 on: 09 February 2012, 16:21:18 »
iirc, there was a post not so long back about using an air pressure hose to blow crud out of the pipes etc...carefully of course :y
AKA - Mr Bracket
« Reply #29 on: 09 February 2012, 16:26:30 »
Oh deer  ::) ::) ::)
Pages: 1 [2] 3 4  All   Go Up
