Pages: 1 [2] 3  All   Go Down
Author Topic: Dispak duties !  (Read 6754 times)
Murph
  • Dartford, Kent
    • 2.5 Estate
Re: Dispak duties !
« Reply #15 on: 07 February 2012, 15:43:46 »
^^^ That's exactly how I did mine.
The problem I had was that the replacement I got was the wrong one (surprise!) so I mounted it below the air box pro tem - just til I get another (correct) one.
Hey ho... it's running!
Re: Dispak duties !
« Reply #16 on: 07 February 2012, 17:13:40 »
Shop rang up today , yes we have your new dispak in today BUT the suppliers have sent the wrong one  >:( >:( >:( >:( great  ::) Another mig-less week as the part wont be in till thursday then prob 2 days hrs ;D putting it all back together  :D
Re: Dispak duties !
« Reply #17 on: 07 February 2012, 18:17:38 »
Not sure if I have a spare in the garage, depending where in Northants you are ::)
Re: Dispak duties !
« Reply #18 on: 07 February 2012, 18:45:24 »
PM  sent  :y
Re: Dispak duties !
« Reply #19 on: 07 February 2012, 19:19:21 »
I have an easy method for changing DIS packs.
Tools needed:
A plank of wood.
Another plank, AKA The Useless Student...
 ;D ;D ;D :y
ps: plank of wood is good idea , I'm scared me or the mechanics will break something whenever we work :y
and the picture is a nice memory , keep it :)
Re: Dispak duties !
« Reply #20 on: 08 February 2012, 08:27:15 »
Thats a few years old that picture, that t-shirt was one of my dads spares I think, which became a car working one.
Re: Dispak duties !
« Reply #21 on: 08 February 2012, 18:12:57 »
2pm the phone went ," we have your coil pack in " ......wooo. Got it so i will be out in the baltic weather early in the morning fitting and re fitting bits and bobs if i can remember where it all goes back  ::) if my hands dont freeze ill take a few more pics and hopefully this nut busting car will run  ;D
dan-eboy
  • West Sussex
    • Omega 2.5 V6, tourer
Re: Dispak duties !
« Reply #22 on: 08 February 2012, 19:08:18 »
Fingers crossed!
Re: Dispak duties !
« Reply #23 on: 08 February 2012, 19:19:12 »
Fingers crossed!
Me too , better get stuck into it sharpish as its forcast 4 inches of snow here friday and my hip's playing up with all the climbing on top of the engine .
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Dispak duties !
« Reply #24 on: 08 February 2012, 20:27:10 »
Good luck, EMD. Looks like you got it sorted  :y
I have just got to clean breathers at the weekend and replace plenum. Going to also take the HBV out and replace so I can tick that on my ''Done'' list of the many jobs that may/will come up.
When cleaning breathers is there any attention I need to give to the 4 tubes that attach to the breather bridge?
RIP Paul Lovejoy
Re: Dispak duties !
« Reply #25 on: 08 February 2012, 20:36:24 »
Yep,take them off and lean them out. :y  RTFG.  :P ;D
Re: Dispak duties !
« Reply #26 on: 08 February 2012, 20:39:33 »
I usually take the breathers off and make sure the are clear all the way through , the only one that was partially blocked on mine was the small pipe to the metal housing like the one you asked about the other day and all the rest were clean . The one on the housing has a small brass connector which needed unblocking on mine , luckily it came out with the pipe after a bit of wriggling . In the past on my other migs some of the pipes were thick with mayo so used carb cleaner and a wire to poke through the mayo  :y
Webby the Bear
  • Northampton
Re: Dispak duties !
« Reply #27 on: 08 February 2012, 20:41:31 »
The guide doesn't mention the 4 tubes Scralbs  :P :P :P ;D ;D ;D ;D
http://www.omegaowners.com/forum/index.php?topic=90653.0
RIP Paul Lovejoy
Re: Dispak duties !
« Reply #28 on: 08 February 2012, 20:44:17 »
It seems to count the Y piece as one tube,which I suppose it is.The other small one doesnt tend to get blocked up so much ime,but might as well clean it while your doing the others. :y
Webby the Bear
  • Northampton
Re: Dispak duties !
« Reply #29 on: 08 February 2012, 20:45:26 »
Cheers m8 ;) i take it carb cleaner down those 4 tubes is ok?  :y
RIP Paul Lovejoy
Pages: 1 [2] 3  All   Go Up
