Pages: 1 2 [3]  All   Go Down
Author Topic: Dispak duties !  (Read 7770 times)
Re: Dispak duties !
« Reply #30 on: 08 February 2012, 20:47:56 »
Usually yes (remove them from the car first),but it depends how blocked they are.sometimes a good soak in petrol or similar helps if they are bad.A long,thin,stiff brush would be the ideal thing to push down the bigger one(s).
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Dispak duties !
« Reply #31 on: 08 February 2012, 20:49:06 »
Not sure what I'd do without you.... Lover.  :-* :-* :-* :D :D :D :y :y :y
RIP Paul Lovejoy
Re: Dispak duties !
« Reply #32 on: 08 February 2012, 20:50:47 »
Never done mine any harm , gunk ive used as well so all depends on how bad they are  :y On the prev mig the mayo had dried and blocked the pipes solid  :D No wonder the rocker gaskets blew when i put it in sports mode  >:(
Webby the Bear
  • Northampton
Re: Dispak duties !
« Reply #33 on: 08 February 2012, 20:55:15 »
I'm pretty sure I have some pipe cleaners I'm going to shove down there. If i need something a bit more ''industrial'' i'll raid the tool box  :y
When cleaning those 4 holes on the breather bridge (4 very small holes in the small circle thing lol) can i shove a needle down there and wiggle about to clean or would that do damage?  :-\ :y
RIP Paul Lovejoy
Re: Dispak duties !
« Reply #34 on: 08 February 2012, 21:00:51 »
Plenty of carb cleaner blasted down there should do the trick.
Re: Dispak duties !
« Reply #35 on: 08 February 2012, 21:02:05 »
If you mean the breather box , tbh i would use something plastic in the brass connector but it should clean easy with squirt from brake cleaner a few time or leave it to soak overnight  :y
Albs beat me to it  ;D
Webby the Bear
  • Northampton
Re: Dispak duties !
« Reply #36 on: 08 February 2012, 21:06:32 »
Cheers all  :y :y :y :y :y :y
RIP Paul Lovejoy
Re: Dispak duties !
« Reply #37 on: 09 February 2012, 13:32:30 »
Finally we have lift off , job done and firing on all 6  :y
What a mess ... !!
The culprit and 5 champion plugs and one NGK , the NGK was the hardest one to take out passenger side back . Someone never bothered with it on the last change  ::) ::)
A handy ratchet set up for the dispak bolts  :y
One for MR WEBBY ...the Y piece  ;D   :y
Took about half hour to fit the coil pack and nearly 2 hrs putting everything back together around it  :y :y :y
« Last Edit: 09 February 2012, 13:34:24 by eatmydust »
dan-eboy
  • West Sussex
    • Omega 2.5 V6, tourer
Re: Dispak duties !
« Reply #38 on: 09 February 2012, 14:54:28 »
Nice one!  :y
Re: Dispak duties !
« Reply #39 on: 09 February 2012, 18:34:40 »
Another success story :y
Webby the Bear
  • Northampton
Re: Dispak duties !
« Reply #40 on: 09 February 2012, 20:22:56 »
Well done matie. Cheers for the Y pic.  ;D ;D ;D
just posting up some pics in a few mins of some breather cleaning ive done today  :y
Well done EMD  :y :y :y
''OOF, and the dirt is gone''
RIP Paul Lovejoy
Pages: 1 2 [3]  All   Go Up
