Sourcing Polly rear donut bushes.
Started by feeutfo, 07 February 2012, 20:22:54
Quote from: Zippy2012 on 27 February 2012, 20:32:40
ide defo be interested!!  :y  :y  :y
just found this thread after posting somthing similar!!!
How about supplying them a full standard set of rubber bushes & get them to make a full set!!!
for everything required on the suspension, wishbones, antiroll bar "both" rear donuts, diff mountings, antirollbar link rubbers etc etc
would be great if you could get everything made in poly!! stiffen them up nicely  :y
well atleast chris you'll be able to do them with your eyes closed after fitting 20 rear sets!!
Initial approach was regarding Donut bushes as these are the most common failure. Paul did take several photographs of various other possibilitys. But he did comment that the rear diff blocks where not so straightforward to make for them. These don't fail as often either, so perhaps may not justify production costs.
They did mention the German Market was good for the omega so it may be a case of wait and see. I can't see rear roll bar bushes being too awkward to make, I guess they may have similar sized eyelet bushes for other models.
But donuts are the main issue at the rear. Let's see how that goes. :)
Mr Gav
Quote from: chrisgixer on 28 February 2012, 00:07:19
Probably the biggest benefit to the car too along with the front wishbone bush.
Quote from: Mr Gav on 28 February 2012, 20:24:45
Yep, and poly the troublesome bushes and I reckon you have eliminated a few common failures and tightened up the handling significantly with little adverse effect on ride comfort.
Poly everything is going to be a route few will want to take, IMHO, because I expect it will compromise the ride more, for a diminishing return in handling.
Elitenut
Put me down for a set please Chris, just notice this after coming off holiday.
astroblaster
Put me down for a set please chris :y
Do it today cause tomorrow it might be Illegal
Shackeng
Sorry, came to this late, put me down for a set please Chris. You did my TD Estate last year, but I'll take a set for the Elite 3.2. :y
I make that 23 definates. And 2 possibles. :y
Spoke To Paul at powerflex today. Sadly we are not on the list of confirmed projects in progress yet. He's asked me to ring again mid week for an update.
Bit disapointing tbh, but there are numerous more profitable projects that financially they can't ignore. Can't argue with that really. Just hope we don't slide too far down the list. Fingers crossed. :)
Seth
Can ya stick moi down for a pair Mr Gix please?
Update. Spoke to Paul at Powerflex recently, we are on the project list. :y
BUT as said, they are following far more profitable lines for other cars first. So likelyhood is production won't be for another 6 months or so. :(
Mr Gav
Bu66er, I was hoping it would be sooner rather than later  :(
My donuts are shot but I did`t want to do them twice.
joff
Hope my brother's get past the MoT in may then or will have to use normal one's oh well ???
MV6Danny
Quote from: Mr Gav on 06 April 2012, 14:39:03
Quote from: joff on 06 April 2012, 16:01:54
As above hope mine gets through mot in may aswell as i dont really want to do mine twice if it fails then standard ones it is.  :'(
Back in the MV6 again now
Guys I think you need to proceed on the assumption we "may" not get them made at all. It was never guaranteed these would go into production.
  If you know your bushes are past it, replace them (IMO). If you then have an issue or imbalance in feel front to back lets hope we have a solution from powerflex to fix that. If we don't get them made, we've lost nothing. If we do get them made, fantastic. :)
vxlgsi
#89
Im about to buy a set for my calibra, been told they are the same as the omega ones. when they turn up ill have a look and see how much work is in them. Might be able to come up with a way to make them.
