Author Topic: Disco won't start  (Read 2942 times)
hoofing it
Disco won't start
« on: 09 February 2012, 08:04:29 »
Just serviced my disco all the filters and oil change done my usual of filling up fuel filter before re-fitting and the bitch won't start.
There is no power to the fuel pump solinoid,starter or glow plugs(im thinking imobiliser)
Ive got it going via a small re-wire job ;) to fuel pump and starter. The glow plugs are manual heat.
Ah the joys of a landrover ???
any thoughts :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Disco won't start
« Reply #1 on: 09 February 2012, 09:02:07 »
I did one that the wire from the fusebox to the fuel pump was shorting out. If I run a live wire from the battery to the fuel pump it would start straight away. So I run a new wire from the fusebox, job was a good en. :y
hoody
  • Scotland
« Reply #2 on: 09 February 2012, 09:50:26 »
Do the electric windows work?(strange question i know)
hoody
  • Scotland
« Reply #3 on: 09 February 2012, 14:10:01 »
Got to go to work,check your fusable links,two thick wires that run along the top of the drivers side inner wing(in a shroud ,the link part).
hoofing it
« Reply #4 on: 10 February 2012, 07:58:24 »
windows ok the central locking through a hissy fit until I took the battery off then re-connected it again.
Daz  I took a feed from the ignition to the fuel pump and rewired the starter solinoid so its all go for now ::) in fact its going better.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 10 February 2012, 15:26:29 »
Good glad you got it sorted :y
