Author Topic: 2.2 16V AUTO ESTATE shuddering/wobbling motion  (Read 4798 times)
GT
  • Bedfordshire
    • Omega 2.2L 16V CDX
    • Team UK Advanced
« on: 12 February 2012, 07:56:52 »
OK Gurus,
i carried out extensive road testing yesterday, as with regards to shuddering/wobbling motion whilst driving, basically you can begin to feel the symptons around 35mph and continue into the 80's (i didnt go any faster), and when braking i noticed that the car shudders ( not a lot but it is noticeable).
I have had previously (a week ago, when i brought it) the tracking done and two new tyres on the front, complete with front wheels balanced too.
So guys, what do you think, have i purchased a lemmon  :-[, shes only done 54k nice conditionnlots of toys etc, but i am worried she is gunna cost me a bomb to repair..
looking forward to your input, and if anyone lives around dunstable, who can cast an eye over it for me, i would be greatful :)
Regards
GT
You Light um and I'll fight um!!
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: 2.2 16V AUTO ESTATE shuddering/wobbling motion
« Reply #1 on: 12 February 2012, 08:06:11 »
was it just the front you had the tracking done ,or was it a full geometry set up ??  :-\
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #2 on: 12 February 2012, 09:06:10 »
well i dont know know, they put a lazer on each wheel, and he said the front was out by 3 points or so  :(
noel
  • frome somerset
« Reply #3 on: 12 February 2012, 09:51:56 »
did this problem only occur after the tracking was done  :-\
just another thought have they tightened wheels nuts up,should'nt happen but can.
« Last Edit: 12 February 2012, 09:56:48 by noel »
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #4 on: 12 February 2012, 10:15:09 »
warped front discs causing steering wheel wobble on heavy braking?
buckled alloy or defective tyre fitted somewhere causing vibration whilst driving?
i assume you have checked these items since you started the first thread ? :)
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #5 on: 12 February 2012, 11:47:38 »
Hi
I have checked the alloys out, they are fine, i have had the front tyres changed, and when i checked the rear wheels the tyres looked OK
With regards to the discs, would this not have been picked up when the new tyres and tracking were done ?
How do i check the discs
GT
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #6 on: 12 February 2012, 12:48:24 »
ide check the front discs for scoring and un even wear,under heavy braking if you can feel the brake pedal pulsating as well as the steering wheel wobbling, imho, youve got warped front discs.best to change discs and pads at the same time.. :)
always worth having the back tyres checked for bulges before balancing..
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #7 on: 12 February 2012, 16:42:50 »
i  will check to see if there is any pulsating, as well as steering wobble..
So if i get any pulsating, it could be the discs,
If i get steering wobble it could still be the balancing
Anything else,
Will report back as soon as i know
Regards
GT
bigdods
  • Brackley
« Reply #8 on: 12 February 2012, 17:49:24 »
I had an egg shaped alloy that gave similar symptoms. It was only apparent when on the wheel balancer you could see it was out of shape as it was spinning
Knackered wishbone bushes can cause odd vibrations as well , worth having them checked although if you've had a full geo done if was somewhere decent they should have checked those as part of the alignment....
Worn/faulty dampers , also fairly easy to check.
Out of balance wheels are of course the obvious one, if the vibration is felt through the seat its the rears , if the steering wheel is wobbling then its the fronts. You dont generally feel the rear balance issue until you reach speed whereas front balance is usually obvious as soon as you are moving.
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #9 on: 12 February 2012, 17:53:30 »
 :) cheers bigdods
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #10 on: 13 February 2012, 14:20:13 »
OK Eyes down Gurus,
After reading through all the comments do to with my problems with the wobbling etc, i took the car back to national tyres, and had them recheck what they had done, the list is what they found
>Tracking OK
>Front wheels out of balance my 15g & 20g, Rebalanced for free
>Rear wheels, well out of balance, now balanced cost £14.50
>Disc and pads on the front are worn, need to change them...
so we are getting somewhere gents, thanks for your help  :y
GT  ;D
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #11 on: 18 February 2012, 18:43:23 »
Front Discs & pads now renewed, drove it home today from work, the drive was lovely  :y
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #12 on: 18 February 2012, 19:36:26 »
lovely jubbly... :)
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #13 on: 20 February 2012, 01:10:16 »
Yesterday, car drove fine, infact lovely, today driving to work, the car is slightly vibrating/wobbling, what can this be... could the suspension be at fault... could it be something simple .... answers on a post card please  ;)
GT
« Reply #14 on: 20 February 2012, 07:01:12 »
Describe the wobble in more detail. Is this a left right wobble through the steering wheel for instance?
