Author Topic: Manual conversion  (Read 4078 times)
Re: Manual conversion
« Reply #15 on: 12 February 2012, 21:08:58 »
Hmmm. 4.2 dif currently. Suck it and see.
First glance at speed range chart suggests 4.2 gives 25mph in first,with top wack at 140, which sounds a bit short...  but then 3.9 gives 27 in first and 150 top wack.
Acceleration will be good but changing gear in quicker succession might be tiresome. I guess we'll have to see. :)
I do miss blipping on down changes.
what I like with 4.22 diff car go on every gear same from 0 to 140+ speed just keep going :)
with 3.9 diff will go over 150 easy , but where you going to drive this sort of speed in uk? ::)
Exactly why I fitted 4.2.
Divided by 5 gears, instead of 4, hopefully the effect will be more dramatic. :)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #16 on: 12 February 2012, 21:19:53 »
swap for a diesel 2.2 diff? 3.45 ratio then :D
V8!!!!
2woody
  • Northumberland
« Reply #17 on: 13 February 2012, 10:15:15 »
the one in your garage is 4.22 !
I'd stick with the standard set-up at first, but paying careful attention to the change linkage.
Other than that, I'm planning a BMW linkage and a lighter flywheel.
« Reply #18 on: 13 February 2012, 11:00:22 »
Cam-belt gear box party at 2woodys then ?  :)
« Reply #19 on: 13 February 2012, 17:19:59 »
That's a party I'm steering well clear of!  ::) ::) ::)  ;D
serek
  • huntingdon
    • 3.2 mv6
« Reply #20 on: 13 February 2012, 18:21:18 »
sound good for me
lets have party ;D
2woody
  • Northumberland
« Reply #21 on: 17 February 2012, 13:32:47 »
it'll have to be after May.
Leave work on 2nd March.
Lots to do arounfd the place in March & April
Off to USA engine shopping for pretty much all of May
« Reply #22 on: 17 February 2012, 14:35:39 »
You're going to need a big suitcase! ;) What are you going to bring back? I'm guessing something(s) big, GM and with the right number of cylinders..
Page created in 0.05 seconds with 21 queries.
