Author Topic: I don't suppose anyone has an air-powered windy gun near me?  (Read 9852 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: I don't suppose anyone has an air-powered windy gun near me?
« Reply #15 on: 13 February 2012, 21:31:43 »
oh and also work that forward backward button a bit in case that is stuck inbetween  :y
« Reply #16 on: 13 February 2012, 21:34:17 »
Sounds as though either a seal has failed inside the control valve or there is a blockage inside it. :-\
That's the sort of conclusion I was coming to.. I'll steal borrow Chris's gun and test it at some point..
aaron i know it sounds silly but have you a speed setting on the gun, just asking incase it is inbetween speeds that would cause it not to operate and just let air through  :-\
Nah - there's just the trigger, the 'forward/backward' button (which I've pushed 129387123 times ;D) and the torque setting wheel (which I've repeatedly fiddled with) :(
It is only a 'PowerCraft' make, mind, so it was cheap..
fiend61
  • york
  • each to their own
« Reply #17 on: 13 February 2012, 21:36:10 »
PowerCraft
theres your problem  :y
sorry couldnt resist  ;D ;D ;D
on yhe plus side if it still looks new you should still be able to exchange it from  where you bought it from with or without receipt  :y
tidla
  • solihull
fiend61
  • york
  • each to their own
« Reply #19 on: 13 February 2012, 21:39:07 »
http://www.ebay.co.uk/itm/Windy-Gun-/200711981018?pt=UK_Air_Tools_and_Compressors&hash=item2ebb5dc7da
think thats the bugger the gorilla mechanic done my wheel nuts with  :(
« Reply #20 on: 13 February 2012, 21:41:38 »
just get yourself another one.
might need a bigger hose. ;D
Not clear if it is 3/4 or inch drive from the picture, but they're a bit on the heavy side either way ::)
« Reply #21 on: 13 February 2012, 21:47:41 »
Aye, there's an old adage about never buying cheap tools, I'm sure..  :-[
 ;D And a bigger compressor, I should think!
« Reply #22 on: 13 February 2012, 22:49:11 »
£200 deposit on tool hire.  ::)
« Reply #23 on: 13 February 2012, 22:59:17 »
Cor, you don't come cheap, do you ;D I could buy a whole new gun for that  :P
'course if I do that it's bound to turn out to be something else ;D
I realise Sealey & Draper aren't 'top tier' brands like SnapOn, but there's some decent looking ones here: http://www.justoffbase.co.uk/Tool-Shop/1-2-Drive-Air-Impact-Wrenches
Not that I know the first thing about windy guns, really, aside from knowing mine doesn't work  :'(
« Reply #24 on: 14 February 2012, 01:02:57 »
mine cots £30, runs off a 25 litre tank on a 30metre retractable line. Only problem I have is it doesn't quite have enough oomph to undo wheel nuts at 110nm.
« Reply #25 on: 14 February 2012, 10:53:23 »
I wouldn't mind betting yours looks a lot like mine, too - all the cheaper ones seem to be identical (I imagine they come out of the same Chinese factory).. feeling any better yet so I can come 'round and borrow it? ;)
Or you round here, if you don't want to let it out of your sight.. ;D
« Reply #26 on: 14 February 2012, 11:24:41 »
Pm me your address A.
« Reply #27 on: 14 February 2012, 11:44:19 »
You have a PM, Chris  :y
« Reply #28 on: 14 February 2012, 16:17:16 »
Thanks to Mr Gixxer I can now confirm that the problem is, in fact, my windy gun .. which is a big bag o' brown stuff.
So I've ordered a new one - nothing too fancy, but at least it's a reputable make this time ;D (No, not SnapOn ;D ;D)
« Reply #29 on: 14 February 2012, 17:49:16 »
Having owned a Snap Off windy gun and now owning an Ingerssol Rand one I know which I would recommend (and it isn't the Snap On one) ;)
Pages: 1 [2] 3 4  All   Go Up
