Author Topic: Dash Warning lights problem  (Read 9096 times)
  • Auckland
    • Mazda MPV
Re: Dash Warning lights problem
« Reply #15 on: 12 February 2012, 18:51:49 »
Codes as follows
1717
1713
5135
1353
1313
1121
2121
2.5 doesn`t flash 4 digit codes does it ???
17   Knock Signal Circuit 2 [check for trapped wire]
135   Telltale (Checklight) Voltage Low [historic - bulb missing]
31   No Engine RPM Signal [engine not running]
12  [end of data]
venom
  • South Moreton, Oxfordshire
« Reply #16 on: 12 February 2012, 19:32:59 »
Paperclip test on that, not pedal trick.
ABS/TC lights point towards ABS ECU - they come up on here for around £40, but a bitch to fit.
I'll have the ABS ECU off of my 2.5 CDX.
What year was the cdx?
It's a 97 I'm still driving it at the mo :y
Hmmm, might be out of luck. What is the last letter of the VIN - if its V, cry, if its W, happy days :)
About right FFS, it's V  :'( :'(
Ken
« Reply #17 on: 12 February 2012, 19:37:21 »
Incompatible I'm afraid, as your CDX one is a 3 channel system, post 98 is 4 channel.
venom
« Reply #18 on: 12 February 2012, 19:43:20 »
Typical  :-\  so will that or any of the codes cause the EML to stay on?
« Last Edit: 12 February 2012, 19:44:55 by venom »
Ken
« Reply #19 on: 12 February 2012, 19:47:06 »
That ECU will only bring on ABS and TC lights. Its unrelated to the engine management light.
Engine light is probably the 17.
  • Auckland
    • Mazda MPV
« Reply #20 on: 12 February 2012, 19:53:32 »
Probably going to be less trouble to send it to BBA reman. All the reports on here seem to be positive. For around £100 will get your ECU back & no worries about having to get it coded to match the car.
That said......... you could get someone to connect it to Tech 2 to check that it isn't complaining about a faulty wheel sensor first.
venom
« Reply #21 on: 12 February 2012, 19:56:39 »
Hello TB ;D
Ken
venom
« Reply #22 on: 13 February 2012, 21:19:46 »
Right my daughters boyfriend is a mechanic so took it to his garage today & he used a Snap on Verdict diagnostic machine & it show up the fault VALVE RELAY CIRCUIT MALFUNCTION anyone come across this before :y
Ken
« Reply #23 on: 13 February 2012, 21:21:20 »
What valve & what relay :-\ :-\
venom
« Reply #24 on: 13 February 2012, 21:28:18 »
Don't know it just pulled it out when he checked the ABS system, I'm asuming it's built in to the ABS ECU but was hoping it was a seperate item.
Ken
« Reply #25 on: 13 February 2012, 22:10:52 »
What was the code?
venom
« Reply #26 on: 13 February 2012, 22:46:51 »
Don't know didn't say so will take it to him again tomorrow and check it again
Ken
venom
« Reply #27 on: 02 April 2012, 20:41:08 »
Well got around to sorting the ABS/TC but by a fluke rather than on purpose finished off fitting the front hubs & wishbones & bled the brakes then took it for a test drive braked hard & yep the ABS kicked in so tried the TC on some grass & it's back working as well so put the bulbs back in the clocks & they've both gone out  :y :y :y :y :y :y :y :y :y :y :y :y :y
Ken
