Pages: 1 [2] 3  All   Go Down
Author Topic: Scratch removal ?  (Read 7365 times)
Re: Scratch removal ?
« Reply #15 on: 13 February 2012, 20:37:10 »
« Reply #16 on: 13 February 2012, 20:40:29 »
A very good friend of mine who does all of my bodywork, does this 'thing' called a smart touch up, basically what you do it, touch it in with paint, so it actually sits higher than the rest of the paint, when dry sand it down to the 'standard' level, polish it, then apply a tiny coat of lacquer and polish it up again. It's something along those methods, it doesn't make it totally invisible, but if you don't know it's there you won't spot it  :y.
« Reply #17 on: 13 February 2012, 20:45:00 »
Sounds good , similar to what i think ill try with the touch up brush . I think the worst one is on the front wing , ill take some pics when i do it Before/After  :y
« Reply #18 on: 13 February 2012, 20:46:32 »
Let us know how you get on  :y.
« Reply #19 on: 13 February 2012, 20:49:00 »
Let us know how you get on  .
Will do , hope i dont make a mess of it  :-X
« Reply #20 on: 13 February 2012, 20:50:46 »
find a very tiny paint brush and do some practice on paper.. :y
« Reply #21 on: 13 February 2012, 20:59:48 »
Good idea  :y I will point out which was before and after in case you get confused  ;D
dan-eboy
  • West Sussex
    • Omega 2.5 V6, tourer
« Reply #22 on: 14 February 2012, 23:22:15 »
At our bodyshop we sometimes use the method it sounds like you're gnna use, touch up the scratch with paint then 2000 grit wet and we use a Machine polisher but T-cut with water and some elbow grease should do it!  Best you'll prob get without painting.  If you load a pic i can see if you might be able to paint it yourself. Where is it?
« Reply #23 on: 15 February 2012, 08:23:37 »
On the front wing and a few lighter ones on the doors , bloody hard work with TCUT . I was doing one small light scratch and the TCUT didn't seem to cut through the laquer at all  :-\ mind i was doing it by hand , i will load up the worst one so you can see what im up against  :y
« Reply #24 on: 15 February 2012, 10:05:12 »
filling paint and laquer is easier than digging laquer ;D :y you can take it with 2000 grid also, but I'm not sure for your lacquer thickness so cant advice it. :-\
« Reply #25 on: 15 February 2012, 14:14:52 »
This is the worst one ...best shot i could get cos of the shine back  :-\
Omegatoy
  • UK
« Reply #26 on: 15 February 2012, 17:58:03 »
get some farecla G3  if you aint got a buffer its better than t.cut
« Reply #27 on: 15 February 2012, 18:03:36 »
Ok thanks , will see if i can order some  :y
« Reply #28 on: 15 February 2012, 18:24:10 »
bad news.. too long,wide and deep (lower part).. not suitable for a newbie hand.. if you try polishing although the upper part
may give some reult , lower part requires deep work which you may end up with a dull paint without laquer..
mask the scratch area and let it sprayed by a professional..
« Last Edit: 15 February 2012, 18:26:34 by cem »
« Reply #29 on: 15 February 2012, 18:29:25 »
Pages: 1 [2] 3  All   Go Up
Page created in 0.036 seconds with 20 queries.
