Author Topic: R25/R28/R30?  (Read 11822 times)
R25/R28/R30?
« on: 15 February 2012, 20:55:33 »
Please could someone let me know what the actual differences are, between these boxes?
I'm guessing fitting an R25 to a 3.0 or above is a no no, as engine would rip it to bits?
Only asking because, if this wasn't the case, I was thinking of buying Abiton's car for a manual conversion jobbie....
Cheers :y
James
Re: R25/R28/R30?
« Reply #1 on: 15 February 2012, 21:07:22 »
R25 is supposed to be fine in a 3.0/3.2. Only difference was shot-peening of the gears on the R28.
It's not like an auto box where the clutches have to be sized for the torque output.
serek
  • huntingdon
    • 3.2 mv6
Re: R25/R28/R30?
« Reply #2 on: 15 February 2012, 21:10:40 »
you can fit R25 with out any problems to 3.0/3.2
Re: R25/R28/R30?
« Reply #3 on: 15 February 2012, 21:13:41 »
Ooooooo  ::)
What about the Diff...... I suppose I'd see a benefit from fitting the differential from the manual car, too?
Am more interested in being quicker off the mark, than top end speed...
twiglet
  • Norwich, Norfolk
Re: R25/R28/R30?
« Reply #4 on: 15 February 2012, 21:15:35 »
James,
If you want an R25, I can point you in the direction where there is one you can have FOC.
Let me know.  :y
serek
  • huntingdon
    • 3.2 mv6
Re: R25/R28/R30?
« Reply #5 on: 15 February 2012, 21:19:47 »
Ooooooo  ::)
but if you will fit 4.22 diff to car with manual box you will be fast from traffic lights but on motorway you wont see more then 26mpg or low 20 if you go faster then 80mph
I would go for 3.9
Re: R25/R28/R30?
« Reply #6 on: 15 February 2012, 21:20:26 »
James,
Let me know.  :y
Thanks for the info mate, although I'm thinking if I bought a donor car complete, I'd have the flywheel, clutch pedal, and all the little bits etc I'd need to convert...? :y
TBH, I could sell it on as scrap value once I'd ripped the tranny out.... so I'd probably break even / not lose much, anyway...  :-\
Re: R25/R28/R30?
« Reply #7 on: 15 February 2012, 21:22:16 »
Ooooooo  ::)
I would go for 3.9
What will my 3.2 have at the moment? :)
serek
  • huntingdon
    • 3.2 mv6
Re: R25/R28/R30?
« Reply #8 on: 15 February 2012, 21:23:42 »
Ooooooo  ::)
I would go for 3.9
3.9
 live as is and you will see lots differents any way :)
Re: R25/R28/R30?
« Reply #9 on: 15 February 2012, 21:25:17 »
James,
Let me know.  :y
Mmm,I have been having thoughts about a manual conversion recently. ::)
Re: R25/R28/R30?
« Reply #10 on: 15 February 2012, 21:27:39 »
Is this free manual box up by Swindon by any chance?  ::)
Re: R25/R28/R30?
« Reply #11 on: 15 February 2012, 22:00:28 »
Ooooooo  ::)
I would go for 3.9
3.9
3.9 will be fine.. I'm using 3.9 with r25 and the first gear is already very short (although second gear ideal) .. I cant predict how it will be with 4.22..
ps: you will need really long octopussy arms when you try to fill the hydraulics for clutch, pumping and bleeding.. ;D
« Last Edit: 15 February 2012, 22:02:36 by cem »
Re: R25/R28/R30?
« Reply #12 on: 15 February 2012, 22:10:29 »
Must be honest... I am a little worried what my insurance co might make of it... it's already insured as an Auto..  :-\
Re: R25/R28/R30?
« Reply #13 on: 15 February 2012, 22:11:50 »
You'd have to declare it as a modification - 'most' mainstream insurers will let you have a couple of modifications (though they'll charge accordingly depending on your age), or switch to a specialist like Adrian Flux/Sky/etc
Re: R25/R28/R30?
« Reply #14 on: 15 February 2012, 22:12:30 »
if you will continue to use 3.2 , worth every penny.. car transforms to a different one.. go for it.. :y
Pages: [1] 2 3 4  All   Go Up
