Author Topic: Elite 2.5 - Wheel-Judder-Jump on L Hand wheel Only when Turning right  (Read 3911 times)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
I'd say copper grease would be fine for the idler but I'm not convinced that's your problem.
When you take the wheel off, are there any marks on the back of the wheel or on the suspension components that would indicate contact?
Is the flexi brake hose properly routed and not snagging/pulling when you turn the steering (should be easy to see with the front end on stands and the wheel off).
With the wheel back on but the car still on stands, is the wheel free to turn with the steering straight and on full lock?
From your symptoms, I'd suspect the new bearing is dodgy - seen this a few times on after market bearings/hubs where the hub doesn't sit 100% square and makes the whole hub/disc/wheel assembly "wobble".  Do you get any vibration under braking?
« Last Edit: 14 April 2012, 10:57:56 by sjc »
vauxsky
  • Nr Watford, Hertfordshire
    • Elite 2.5 V6 Man(S_1998)
thanks for those comments, what WIMS recomended garage is near me, I am in Hertfordshire, did someone say there is one in Chesham - Bucks.
thank again.
SteveAvfc.
    • Mv6 2.6 V6
Go to the WIMS home page. Chesham is there home depot but they have approved garages around the country.  :y :y
thank again.
vauxsky
Had a look in maintainance guides for suspension settings, can not find them, here are the H****s Maunal ones, can somone tell me which ones ar wrong please before I go to the garage?
OMEGA 2.5 ELITE
Front Wheel Alignment
Camber Saloon: -1deg 40' +/- 45' >>>>>>>>>>>>>>>>> should be -1.10 minutes, plus or minus 0.10
maximum deviation, left to right wheel 1deg
Castor Saloon : 5deg 40' +/- 1deg
Toe-In saloon: 0deg 10' +/- 10'
Variation with inner wheel turned in at 20deg -  1deg 40' +/- 45'
Rear Wheel Alignment
Camber Saloon: -1deg 50' +/- 40'
maximum deviation, left to right wheel 45'
Toe-In Saloon: -0deg 20' +/- 10'
maximum deviation, left to right wheel 25'
« Last Edit: 14 April 2012, 14:22:10 by vauxsky »
Just book it in at Chesham, they'll do the rest.
That's wheels in motion hq. ;)
SteveAvfc.
    • Mv6 2.6 V6
Dito  :y :y :y :y :y
