Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: Low oil pressure at hot idle  (Read 14796 times)
Re: Low oil pressure at hot idle
« Reply #60 on: 31 May 2012, 10:09:28 »
Yeah it is a bit, from inside the cabin you cannot hear it. Only outside, its only at idle though, some revs and you then cannot tell.
« Reply #61 on: 31 May 2012, 18:37:02 »
I've heard it, it really is only the top end, nowhere Deap enough to be bottom end and location is just under the rear(?) of the plenum, and gets very slightly and slowly louder as it warms up on idle.
It's much quieter than the slightest lifter noise I've ever heard, tbh. But it is undeniably there.
I wouldn't worry too much, personally.
There won't be a decission on the Chav for a whole yet btw. But your name is on it etc.
« Reply #62 on: 01 June 2012, 09:25:57 »
Cheers Chris  :y
Yeah I'm not too fussed about it really, still goes fine and driving around normally sounds like it should. If there is a chance to change it, will take it  :)  :y
Pages: 1 2 3 4 [5]  All   Go Up
