Author Topic: How to install a new hand brake cable and a hand brake disc for 2001 omega  (Read 2299 times)
andy_williams95
  • Cardiff
    • Omega 2001
Hi Guys,
I have 2001 omega and I have an MOT coming up soon and one thing that I need to sort out is the hand brake cable and hand brake disc, but the problem is that I don't know how to do it!  :(
Can I have some help please
Thanks
markspark
  • Bolton
Hi and welcome to the mad house  ;D
Have a read here this may help
http://www.omegaowners.com/forum/index.php?topic=90580.msg1155461#msg1155461
jonny2112
  • Bangor NI
    • 2.6 Elite
I did the handbrake cable on my MFL. Imagine it's probably the same in which case it's not difficult, just diddly, particularly adjusting the cable itself due to confined access.
What is the problem with it?
andy_williams95
  • Cardiff
    • Omega 2001
Its not strong if you know what I mean, so i thought about changing it all, but the problem i just need to know how to remove the old one and replace it with a new one  :)
Hi Guys,
Thanks
Your handbrake operates on a drum at the back, the disc you can see is for the foot brake  ;) ;)
The shoes are unlikely to be worn out, they only hold the car when it's already at a standstill (handbrake turns aside  ;D) I'd expect it just needs adjusting as per the guide.  :y :y :y
Latchie_3.0v6
  • OMAGH N.IRELAND
    • Omega 3.0 v6 elite (sold)
I done this last week on my mfl. Jack up rear of car secure with axel stands. Get to about half way down car and remove heat sheilds. You will see a bolt connecting to a bit of plate with two cables coming out of it. Get a 13 mm socket and loosen of nut. Get to about  the rear wheels and take of more heat sheilds and unclip handbrake cable from a C shape bit of steel. On back of disc remove spring then cable. Do same both sides and remove complete cable. Fitting is same as removal the way I done it was first put cable onto bolt at centre of car and then feed cables to the rear.
To change disc take off rear wheel Use flat head screwdriver and loosen handbrake shoes. undo 1 bolt holding on disc. Take a 19mm socket and take of calibre then disc should just come free.
The only way forward is sideways
Latchie_3.0v6
  • OMAGH N.IRELAND
Hi Guys,
Thanks
Mine had worn down to steel I changed cable then ended up changing shoes aswel.
which is why I said unlikely and not 'won't be'  ;) ;) There's no reason why the shoes would be worn at all, as said above, a handbrake is deigned to hold stationary a car that's already stopped.  ;) ;)
John-R
  • Liverpool
    • 2003 2.6 V6 CD
I too have a handbrake issue.
The other day when I pulled the lever it seemed to give way like a cable had snapped but everything still functioned ok.
The lever appears to rest to one side and there is a bit of sideways travel.
Any ideas ?
Cheers.
You can pick your friends and you can pick your nose . . but you can't pick your friends nose !
tidla
  • solihull
like you say Andy, handbrake is there for when you are stationary, so in theory no wear should take place at all. Yet when i bought my car, first thing i did was to adjust the shoes up so the hand brake was on one notch.
now after 10k in 2yrs, it on 4 notches. ?
no j turns as displayed in a certain you tube video, so i guess just cable stretch.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Have a look under the back end where the cables are clamped to the rear arms  :y
I had a similar problem.
It turned out that the cable had pulled threw the clamp and had become loose.
If so, just push it back into the clamp and adjust it with a hammer until its tight  :y
andy_williams95
  • Cardiff
    • Omega 2001
Thanks guys, I will have a go at this in the next couple of days and if there is any more problem i will come back to you guys
Thanks
Thats easy, not nearly enough slack in the cable and hence everytime you put some load in the back or hit a bump, the movement of the rear suspension will cause the shoes to very slightly apply and wear them out.
Hence why I did a detailed guide on what to do....the setup is simple and servicing and adjustment is not hard but MUST be done in a specific order and with some slack in the cable when its released.
Page created in 0.076 seconds with 20 queries.
