Author Topic: Astra engine change  (Read 1878 times)
Jono.01
  • Kent
    • 2001 omega 2.2dti
Astra engine change
« on: 20 February 2012, 22:31:26 »
Hi all,
I know this isn't omega related but was looking for some help with the mrs car!
Recently a van has crashed into my wife's 2000 Astra 2.0dti and written it off, the car had done really low mileage and engine was really good, I have bought the car back from the insurance company and also bought a 2001 Astra 2.0 dti with a knackered engine.
I'm planning on swapping the engines but not sure what I need to do about chipped key, transponder on the fuel pump and the ecu etc?
Any help/advice would be greatly appreciated!
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: Astra engine change
« Reply #1 on: 21 February 2012, 03:20:25 »
I'm not expertising the Astras but if followed the logic of Omega I would say you : no need to do anything more if you stop at engine change. You should do some other things just in case of swaping ECU, immo or ignition key. Good luck bud!  :y
C20NE - X25XE
Jono.01
  • Kent
    • 2001 omega 2.2dti
« Reply #2 on: 21 February 2012, 11:50:13 »
So do I need to change ecu and key chip aswell, the engine from the 2000 dti will be going in with the fuel pump from the 2000 dti??
mantahatch
« Reply #3 on: 21 February 2012, 12:00:17 »
Not to sure on diesel, but if the ECU is part of the injector pump then I think you will need to chage immobiliser chip but not remote locking bit of key.
Hope that makes sense.
