Author Topic: Snipped wires  (Read 2886 times)
Snipped wires
« on: 21 February 2012, 15:30:15 »
My wires to the brake pad sensors have been snipped , the display has always shown brake pad warning check but the brake pads are fine . There is 3 wires , which ones do i join together to stop the brake pad check displaying  :-\
Tia  :y
chrisdb
  • Chesterfield
Re: Snipped wires
« Reply #1 on: 21 February 2012, 15:41:32 »
Hmm... there should only be two wires and you simply join them together, but you'd be much better off spending a couple of quid for new sensors - they break so often when changing the pads that they are dead cheap and only take a minute to fit. :y
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
Re: Snipped wires
« Reply #2 on: 21 February 2012, 15:48:54 »
Mmm  :-\  I was doing a coolant change and while my head was under the front i glanced back to have a look and sure it was 3 wires ...no other wires should be near the brakes should they  :-\
I will go and check ................
« Last Edit: 21 February 2012, 15:52:55 by eatmydust »
Re: Snipped wires
« Reply #3 on: 21 February 2012, 16:06:57 »
Definately 3 wires ..............should i join them all up  :-\
Re: Snipped wires
« Reply #4 on: 21 February 2012, 16:12:31 »
Post a pic. :y
Re: Snipped wires
« Reply #5 on: 21 February 2012, 16:17:59 »
Post a pic. :y
Hope its not something else thats been snipped other than the sensors  :o
Ill have to take a picture thursday as a bit tied up at the min , ive been working on the car all day  ::)
Re: Snipped wires
« Reply #6 on: 21 February 2012, 19:42:24 »
In my haste to fix things before they break being a mig owner i made a boo boo  :-[ :-[ :-[ just looked more closely and ABS and break sensors are all intact  ::) can i just snip the 2 break sensor ones and re join them together ...struggling to see where they connect as i cant get the wheel off as some numpty before me over tightened the wheel bolts  :y
The 3 wires i spotted seem to have come out of the wiring loom that run into the engine bay , aux for something ...strange but cant see anywhere they could have joined to . Not causing concern as my wires are all intact to the brake pads ans ABS  :y
« Last Edit: 21 February 2012, 19:56:02 by eatmydust »
martin42
Re: Snipped wires
« Reply #7 on: 21 February 2012, 19:57:14 »
should be able to remove the cable from the connector on wheel arch liner and insert a paperclip into both holes and tape up,thats what i did on mine and been ok since,im about at the weekend if you need a hand mate :y
Re: Snipped wires
« Reply #8 on: 21 February 2012, 20:00:34 »
Would be good if you could pop over martin , need to get these wheels off ...all 4 have been over tightened and ive snapped the extension putting too much leverage on it  ::) dont suppose you have a breaker bar ...if not ill pop down garage and get them loosend first  :y
Re: Snipped wires
« Reply #9 on: 21 February 2012, 20:03:06 »
... and insert a paperclip into both holes and tape up, ....
Much better to use the plug & cable of an old sensor to short the terminals out. A paper clip will end up a rusty mess inside the socket especially as it lives in the wheel arch where it'll be drowned on a daily basis.
martin42
Re: Snipped wires
« Reply #10 on: 21 February 2012, 20:07:40 »
thats all i had to use at the time,the socket was left exposed as no wire was left the to join the 2 together  :D
Re: Snipped wires
« Reply #11 on: 21 February 2012, 20:18:13 »
PM sent  :y
