Author Topic: Juddery startup.  (Read 5494 times)
Juddery startup.
« on: 21 February 2012, 17:52:30 »
Right one of my beemers has a very very poor startup from stone cold, I always leave it for the glow plugs to warm, however when it starts it's judders around like an old tractor, feels like it is heavily misfiring. After about 10 seconds it clears and runs absolutely perfect. Any ideas what this could be as it really is driving me mental now to be honest. It's a 231 BHP 3.0 diesel, I've had to ask on here because no one else seems to want to give me answer.
Re: Juddery startup.
« Reply #1 on: 21 February 2012, 18:13:49 »
« Reply #2 on: 21 February 2012, 18:17:39 »
Thought it would be an injector problem  >:(.
« Reply #3 on: 21 February 2012, 18:21:20 »
Thought it would be an injector problem  >:( .
3 possibilities, glow plugs , glow plugs controller , injectors.. :-\
I just remembered how much I spend for a hot starting issue on a normal fuel car >:(
« Reply #4 on: 21 February 2012, 18:38:40 »
Always starts first time, it's just the initial startup in hitch it really really feels poorly.
« Reply #5 on: 21 February 2012, 18:43:06 »
probably your car is newish.. if you wait it will get worse and easily solve the problem ;D :-\
« Reply #6 on: 21 February 2012, 18:49:09 »
It's a shame I haven't caught it on video yet, I'll try in the morning as its terrible.
« Reply #7 on: 21 February 2012, 19:00:07 »
« Reply #8 on: 21 February 2012, 19:05:16 »
This is pretty much what it does
http://www.youtube.com/watch?v=5zPk2Wg0Vf8&feature=youtube_gdata_player
this car is hunting.. so I think its different than the thread I posted above..  ???
« Reply #9 on: 21 February 2012, 19:09:10 »
my miggy was doing the same when it has a faulty vacuum solenoid.. but yours is diesel  :-\
« Reply #10 on: 21 February 2012, 19:11:34 »
See I'm thinking either rail pressure sensor, or glow plugs, or the glow plug control unit. I should point out the car pulls fantastically well an is very very good on fuel, however, it does if you give it some properly end up in limp mode.
« Reply #11 on: 21 February 2012, 19:18:55 »
I suspect a leaky injector..........if it was rail pressure then it would cause heavy acceleration issues.
If it was glow plugs it would just not fire, a modern diesel will pretty much always combust once a single cylinder fires and the crank speed is raised above the starter motor speed.
« Reply #12 on: 21 February 2012, 19:27:23 »
Probably is :(. I'll have to get it on a smooth running test and pinpoint the injector with the fault.
« Reply #13 on: 22 February 2012, 12:31:50 »
Very lumpy idle on hot now, gave it a bootful to try and it broke down. Fantastic  >:(
« Reply #14 on: 22 February 2012, 15:14:42 »
Took it to my mechanic, got him to give it a good thrashing, absolutely stunk of diesel, anyway, popped the engine cover off and the leak off pipe is snapped, and squirting fuel all up the joint. New part ordered, ready to be fitted tomorrow.
