Author Topic: Juddery startup.  (Read 5497 times)
Re: Juddery startup.
« Reply #15 on: 23 February 2012, 21:10:19 »
New leak off pipe was fitted today, started it up applied slight throttle pipe split straight away. Any ideas?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #16 on: 23 February 2012, 22:07:32 »
Just a guess but would a clogged or faulty injector cause enough of a build up of pressure in the return circuit to split the pipe?
« Reply #17 on: 23 February 2012, 22:13:07 »
Yep, it would. I'm unsure of what to do really, any diesel technicians can't look until next week  :-\.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #18 on: 24 February 2012, 00:16:08 »
If the leak off pipes are splitting that quickly it would seem that a injector has way to much return flow that is causing excess pressure on the return system.
other rides
« Reply #19 on: 24 February 2012, 10:11:20 »
Or there is a blockage further up the system that's causing the return pipework to pressurise.
« Reply #20 on: 24 February 2012, 16:10:44 »
Looking at it today it hasn't split the pipe in the same place, it runs fine under light load, any heavy load and it runs like sh1te.
« Reply #21 on: 24 February 2012, 16:24:32 »
Does the return go to the filter or the tank (usualy the filter on modern systems)
« Reply #22 on: 24 February 2012, 16:43:00 »
I'm not sure to be honest  :-\. I've got plenty of images of the common rail system, injection system etc if that's of any help?
« Last Edit: 24 February 2012, 16:45:25 by Del Boy »
« Reply #23 on: 24 February 2012, 17:07:51 »
I suspect you may have a goosed injector, this would result in the mid pressure system being more stressed and hence the weakest part of the chain would go......e.g. a bleed off pipe.
« Reply #24 on: 24 February 2012, 17:17:05 »
That's what everyone is saying to be honest, hopefully it's right and not more than one  :-\
« Reply #25 on: 09 March 2012, 17:47:20 »
Well BMW say there's no injector problem which to be honest I think they're talking utter bullshit, it does this at startup:
http://www.youtube.com/watch?v=bAl7amv6XM8&list=UUCEIquOpNKTJB0SLJ976LNQ&index=1&feature=plcp
