Author Topic: Estate rear seat problem.  (Read 2681 times)
Re: Estate rear seat problem.
« Reply #15 on: 23 February 2012, 06:37:33 »
I had a play with the locking hoops yesterday. Tried moving them a little to the left/right/up/down but didnt help.Looks like I will have to investigate partial removal of the cloth to get at the mechanism. :(
« Reply #16 on: 23 February 2012, 09:54:56 »
Once you figure out how to fix yours.. can you come and fix mine, too?
Wait, what am I saying.. as soon as you've fixed it you'll have forgotten how ;) ;D
I kid. I'm watching this thread with interest - mine seems determined to ssip me off every time I fold the seats back up!
« Reply #17 on: 23 February 2012, 13:25:14 »
I will report back if I get it sorted Aaron. :y
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #18 on: 23 February 2012, 15:41:51 »
how can people think the cable dont have any safty issues, if the bolt as taxi al says is locked over is in place but the one side that stops the seatbelt moving isnt the rear seat will twist and bend in event of a accident, think back to the adverts when showed a accident of a unrestrained person in rear hitting front seats, wasnt it the force of a elephant or simlar, well all that will be pulling on a unfixed area that is designed to do the load bearing, do your own maths
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #19 on: 23 February 2012, 16:10:30 »
Aaron,  i'd be happy to belt yours back in to shape,  ;)
adey2
« Reply #20 on: 23 February 2012, 16:13:51 »
id be happy to do anyones too if stops them removing parts, wonder how many would remove the bolts out the drivers seat and drive down rd,
« Reply #21 on: 23 February 2012, 18:16:46 »
Ok,sorted one side (drivers side).peeled off the fabric cover as much as is needed to allow access to the mechanism.Then pulled the foam back and squirted some wd40 in there.Moved the mechanism up & down several times and then tried closing it, worked every time,so put cloth back as it should be - job done. :)
Did the same with the other side,but it seems a bit different.Mechanism feels loose,possibly something has become disconnected. It was pretty dark by then,so will delve a bit deeper on that side tomorrow.
« Reply #22 on: 24 February 2012, 03:13:30 »
How is that any different from using the outer belt with the seat in the same state?
The point I am trying to make is that with both ends of the seat LATCHED and the centre bolt in place, the seat will NOT move. :-\
If the lock button is fully up then the seat is latched. It's really that simple :y
The centre belt has two seperate mechanisms:
1. The inertia reel, which stops the belt from pulling out under load. This is the safety part and is unaffected by disconnecting the cable in question
2. The tilt switch which locks the reel when the seat is out of position. This also locks the cable release when the seat is unlatched.
NO ONE is suggesting using the seat whilst it is UNLATCHED as that would be criminally insane, surely ::)
WTF?
If the mechanism is sticking through age/lack of use/worn out, disconnecting the cable is neither here or there. Common sense dictates that when you put the seat back up you check that it has latched in the same way you check the bonnet is properly latched when you shut it...
Just my thoughts, you don't have to agree :-X
p.s. A firm thump with the flat of your hand just below the button on the face of the seat will usually see the lock button rise up to the top of its' travel.
« Last Edit: 24 February 2012, 03:15:25 by taxi al »
