Author Topic: Coolant level warning!  (Read 2341 times)
Drewomega
  • Aviemore and Mallorca
    • SKODA Octavia Scout 2.0
« on: 27 February 2012, 13:41:53 »
Hi All OOFers!
My coolant level warning came on yesterday when on a dual carriageway. I stopped and had a look at level in header tank. All was ok. When I got home I checked the plug underneath the header tank and also the float inside. Everything seemed normal. Is this a normal complaint on the Omega? I have looked at other posts on here and I cannot see any answers to my question or even a fix. Thanks!!
I'm always last in the office in the morning but I make up for it by leaving first.
Re: Coolant level warning!
« Reply #1 on: 27 February 2012, 13:44:01 »
Hi All OOFers!
Common fault. Replace tank
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #2 on: 27 February 2012, 14:04:28 »
try pushing float up and down a few times in tank they can sometimes stick  :y
oh make sure it has cooled down first though  :D
Drewomega
« Reply #3 on: 27 February 2012, 15:14:37 »
oh make sure it has cooled down first though ;D ;D
Seem to have fixed it! I took the clip off which attaches the tank to the chassis. I removed plug from bottom of tank and cleaned both plug and socket pins then sprayed with WD40.  :y
fiend61
  • york
  • each to their own
« Reply #4 on: 27 February 2012, 15:35:50 »
nice easy fix then and saved yourself £30 ish  :y
no burnt finger  :y
but no new shiney tank  :(
well done  :y
Drewomega
« Reply #5 on: 27 February 2012, 15:51:52 »
Thanks guys!!  :y :y
