Author Topic: 3.0l lpg cutting out on gas.  (Read 7353 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: 3.0l lpg cutting out on gas.
« Reply #15 on: 27 February 2012, 21:23:43 »
this is easy-on the bottom of your evaporator is a solenoid either its knackered or you broke a wire. Did same 2 weeks ago-solenoid was knackered . :y
Not necessarily ;) But a possibility
i will have a look in the morning as the car is up my garage.
symes
  • oxford
    • R reg 940 volvo
« Reply #16 on: 27 February 2012, 21:24:00 »
on mine i put direct current to solenoid and it wasnt opening valve got new solenoid fitted it and went straight away onto gas.trouble is its in a hot enviroment by side of engine was thinking of making heat shield
« Reply #17 on: 27 February 2012, 21:29:41 »
Further to the last, is the LPG light flashing slowly or quickly, when it won't run on gas?
hi james, the orange light flashes but not quick, all the green lights are on at the same time. as soon as it cuts over to gas the engine dies.
at the moment i dont know if it has gas or not without going to fill it up. i suspect not but doesnt explain why it cuts out like it does.
thanks.
I think I know the answer to this one. Config issue in the Romano, causing it to believe it has no gas when there's actually quite a bit left in the tank...
I always intended to sort it for Dave, but my lead broke  :-[
Now fixed, so more than happy to put right for you....  :y
« Reply #18 on: 27 February 2012, 21:35:01 »
thanks.
Isn't that what I suggested may be the case here :-X ::) ;)
If the lights have changed their behaviour then it's altogether possible that the settings have been lost from the controller and therefore the auto switch-back settings are now wrong ;)
But check what you've worked near first ;)
« Reply #19 on: 27 February 2012, 21:40:04 »
thanks.
Didn't fully read the thread / your post, LD  :-[
Just recall what the issue is, because I what I checked out for Dave...
The Red Baron
« Reply #20 on: 27 February 2012, 21:43:46 »
ok, im going to check over what ive done, connections etc & i will report back tommoz.
thanks for the input so far.  :y
« Reply #21 on: 27 February 2012, 21:43:53 »
Was a wind up really James ;) ;) I've not seen the car but it was just a thought ;) ;)
The Red Baron
« Reply #22 on: 28 February 2012, 15:56:24 »
right, been & checked all the connections i possibly disturbed, cant find any faults tbh. start her on petrol...manualy switch to gas, wont switch over until i rev the engine, switches over(i can hear the injectors ticking) then instantly cuts out.
bum. :(
« Reply #23 on: 28 February 2012, 16:03:10 »
Go pop some LPG in mate :y
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #24 on: 28 February 2012, 16:04:36 »
is there a gauge on the tank to show gas content, had this problem with a vectra and it was showing full but empty of gas
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
The Red Baron
« Reply #25 on: 28 February 2012, 16:33:52 »
yes i will, at least it will give more of a clue.
adey,
No gauge on the tank. as all the lights are on green you would think it has gas, will know better when i go & fill up.
« Reply #26 on: 28 February 2012, 16:40:40 »
adey,
Still maintain what I said before... It sounds like the ECU settings are corrupt so it thinks there's LPG in the tank when it's empty ;) Put some in and at least rule it out. With that done (if it still plays up) we can then start the process of fault finding the blockage ;)
The Red Baron
« Reply #27 on: 28 February 2012, 16:45:31 »
adey,
thats right paul, we will go from there.  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #28 on: 28 February 2012, 17:12:36 »
on saturday mine kept spluttering and dying on me so squirted carb cleaner into main feed pipe to injectors that sorted it - maybe you got same problem.
« Reply #29 on: 28 February 2012, 18:44:49 »
Sounds like yours needs servicing and the heavy ends draining from the reducer :-\
Pages: 1 [2] 3 4  All   Go Up
