Author Topic: Boot mod  (Read 7874 times)
Glassback
  • Sheffield, South Yorkshire
    • Face lift cdx dti
Boot mod
« on: 27 February 2012, 19:54:08 »
I have done the boot mod so I can pop the boot without taking the key out, but I have noticed the interior light delay is always active even when the ignition is on. Has any one else had this after doing the boot mod?
Re: Boot mod
« Reply #1 on: 27 February 2012, 21:17:32 »
Yes, its the side effect....
Agemo
  • Cleethorpes
  • Insignia
Re: Boot mod
« Reply #2 on: 27 February 2012, 21:40:06 »
Yes it's annoying to have the light on as you drive off, I rigged a redundant TrafficMaster switch as a by-pass. Just poke the button & out it goes.  :y
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #3 on: 28 February 2012, 11:02:54 »
Yes I occurred to me to rig a by pass, I was thinking of putting a switch above the boot pop switch on the dash..
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #4 on: 28 February 2012, 20:33:47 »
Can anyone recommend a switch to fit in the blank above the boot pop switch, just to over ride the interior light delay?
Re: Boot mod
« Reply #5 on: 28 February 2012, 20:45:42 »
Can`t you use a TC switch with relevant wiring at the rear as switch is push to make/break
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #6 on: 29 February 2012, 15:53:06 »
Don't know if I can use a TC. switch, does it go above the boot pop on F/L ?
Re: Boot mod
« Reply #7 on: 29 February 2012, 17:09:19 »
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #8 on: 29 February 2012, 19:15:21 »
Cheers mate, Do you have one by any chance.......?
Re: Boot mod
« Reply #9 on: 29 February 2012, 19:17:07 »
Nope, got three ;D :D
Agemo
  • Cleethorpes
  • Insignia
Re: Boot mod
« Reply #10 on: 29 February 2012, 22:32:45 »
Nice one, I suppose if you don't have TC, you would need the backing to the switch too. :-\
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #11 on: 01 March 2012, 11:09:01 »
 You need relieving of one, Two is company Three is a crowd.  ;D
Re: Boot mod
« Reply #12 on: 01 March 2012, 12:33:06 »
Only got the switch, no connecting block that slots into the console surround
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #13 on: 01 March 2012, 13:26:03 »
Will it not fit into the blank in the console? ie. can I drill a hole in the blank to accommodate the switch ?
« Last Edit: 01 March 2012, 13:27:59 by Glassback »
Agemo
  • Cleethorpes
  • Insignia
Re: Boot mod
« Reply #14 on: 03 March 2012, 21:47:58 »
Not quite sure what you mean, are you thinking of mounting a Trafficmaster switch in a blank?
