Author Topic: Boot mod  (Read 7889 times)
Glassback
  • Sheffield, South Yorkshire
    • Face lift cdx dti
Re: Boot mod
« Reply #15 on: 04 March 2012, 13:40:49 »
Only got the switch, no connecting block that slots into the console surround
Will it not fit into the blank in the console? ie. can I drill a hole in the blank to accommodate the switch ?
Not quite sure what you mean, are you thinking of mounting a Trafficmaster switch in a blank?
No, I just want a switch to turn the interior light off. RobG says "Only got the switch, no connecting block that slots into the console surround" But I dont know what he means.
Re: Boot mod
« Reply #16 on: 04 March 2012, 13:47:07 »
Pop the blank out, see what`s behind
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #17 on: 06 March 2012, 16:57:09 »
I've popped the blank out, and it looks like there is a connector block in there, like if the car was fitted with traction control but with the switch missing. There is also a blank on the passenger side opposite the boot pop, that also has what looks like a connector block.
Re: Boot mod
« Reply #18 on: 07 March 2012, 12:58:16 »
Two options if you want the switch in the centre console.
1) fit a push to make/break switch in your existing blank.
2) utilise a TC switch by establishing what are the push to make/break connectors on said switch and connect wires from int. light to suit
Glassback
    • Face lift cdx dti
Re: Boot mod
« Reply #19 on: 09 March 2012, 12:07:20 »
I am thinking if I use a TC. switch in the centre console, as in option 2. I would have to rip out the console the get to the connector. Same thing as in option 1. I suppose I could use the traffic master switch, because I dont use the traffic master, I have been thinking about taking the TM. out for some time now. I have an idea to use a boot pop button from a Carlton in the existing blank. But again it means ripping out the centre console. Or use the Carlton boot pop button in place of the TM. button.
Agemo
  • Cleethorpes
  • Insignia
Re: Boot mod
« Reply #20 on: 24 April 2012, 21:12:42 »
Just curious what the latest is. You already have a TrafficMaster switch you don't use, and you are talking about using a Carlton on, ripping out consoles etc. Any reason you don't use the TM switch?
