Author Topic: F/L 3.0ltr Elite saloon breaking. Z147  (Read 7160 times)
« on: 25 April 2012, 19:57:52 »
MY 2001. Z147 Star Silver.
Seats are SOLD
Engine & box, prov sold.
Lip spoiler, prov sold
Panels, bonnet, doors and both bumpers are good, interior cabin carpet is near immaculate.
C/C panel, no wear on buttons. £25 posted.
Door mirrors. £25 ea posted
Photochromatic rear view mirror. £20 posted.
Wheels fronts fitted with Dunlop Sport 5-6mm, rears Accelera Alpha 4-5mm (both rears have slight wear on outside shoulder). Very little scuff markings. £200 collected.
Full Bose set-up. £50 posted.
2013, GID, GSM aerial + cabling to driver`s kickpanel. 07/08 Navteq CD. Everything works incl. CDC3. Comes with security code. £160 posted.
Re: F/L 3.0ltr Elite saloon breaking. Z147
« Reply #1 on: 25 April 2012, 20:17:50 »
Centre armrest SOLD
« Reply #2 on: 25 April 2012, 20:45:37 »
Lip spoiler SOLD
« Reply #3 on: 25 April 2012, 21:22:43 »
What are doors like?
« Reply #4 on: 25 April 2012, 21:28:02 »
Darn sight better than yours. ;D ;D Very small "line" of surface rust at bottom of n/s rear, scratch (will polish out) below moulding on n/s front both o/s are excellent. Pics of the areas in question.
Scratch
Rust line, not very good pic, about an inch long
« Reply #5 on: 25 April 2012, 22:01:05 »
What are you like getting the prefacelift strips off and reusing them ::)
« Reply #6 on: 25 April 2012, 22:05:14 »
Never done it and I wouldn`t like to try ;D ;D
« Reply #7 on: 25 April 2012, 22:10:10 »
Bugger. That means over £300 on replacement strips :(
twiglet
  • Norwich, Norfolk
« Reply #8 on: 25 April 2012, 22:10:10 »
Very sharp paint scraper, and a tube of tigerseal.  :y
« Reply #9 on: 25 April 2012, 23:24:06 »
Photochromatic rear mirror SOLD
« Reply #10 on: 26 April 2012, 13:36:50 »
Agreed. :y
« Reply #11 on: 26 April 2012, 19:09:14 »
Might need a bit more of a description/technique  :-[
twiglet
  • Norwich, Norfolk
« Reply #12 on: 26 April 2012, 20:23:01 »
Ok, they are held on with very strong strips of double sided foam tape.  Use a very sharp and thin, 2 - 3 wide paint scraper, and work from above and below the trim to cut through the tape.  The doors are scrap anyway, so it doesn't matter about damaging them.  The trick is to work a bit at a time, and let the scraper to the work.  Don't force it and bend the trim.
Once off, clean all the remaining tape off, and use thinners to clean any muck, glue, grease, etc off the trim.
Then use tigerseal or similar to fix to the new doors, or buy some new foam tape, or put down to your local Autoglass and chuck the branch fitter a tenner to prime and glue them on with windscreen adhesive.  Lots of different options here, but if you're not confident I'd use the Autoglass route.  Just as long as you never want to take them off again!!  :o
HTH  :y
« Reply #13 on: 26 April 2012, 21:12:36 »
Thanks Twiglet :y
The scraper, presumably, will only penetrate 2 or 3 mm from top and bottom - cant remember how big the tape is.  Guess its a job best described as 'fiddly' ?
Cheers
twiglet
  • Norwich, Norfolk
« Reply #14 on: 26 April 2012, 21:31:50 »
Thanks Twiglet :y
Cheers
IIRC the tape is approx. 12mm thick.  You'll find that as you get started from one end, you will be able to get the scraper in square on from that end, and wiggle the handle up and down whilst applying firm, controlled pressure.  Patience is absolutely the key.  Lots of little breaks for a cuppa.  ;)  If you overdo it and slip, you WILL bend the trim, at that will be that.  :'(
